Other question is, can i control de filter with keytracking?, the resonance always is in the same frequency.
any ideas??
Thanks in advance.
Fernando.
Shouldn't be hard. You just need a tech to wire it for you. Schematics are easily found online.dancelwerk wrote:hi again guys, i want to add a VCF In, (not an audio in to the filter, i want CV in, to the filter) of my Opus III to control the filter with an VCO in audio range or other LFO in other wave, the Opus III only has triangular wave, the idea is use a switch jack to use when you want the on board lfo of the opus III or use an external signal to modulate the filter. The filter of the Opus is very similar to the minimoog filter and in the minimoog filter you can control the filter via cv in.
Not likely. The Opus III is a top octave system in which pitches for each and every key is generated simultaneously. It's basically a fancy organ. When you press a key, you are routing the pitch for that key and producing a trigger for the EGs but it does not generate any CVs. The only way to add filter keyboard tracking is to add another set of contacts and buss to the keyboard assembly, those parts are simply not available and even it they were it would be more expensive than the instrument is worth.Other question is, can i control de filter with keytracking?, the resonance always is in the same frequency.
