Midi murf midi problem
Monocoque
Post by Monocoque » Tue Dec 03, 2013 8:39 am
Hi this is probably a really silly question so apologies.
Ive just bought a midi murf and set it up as the instructions have said downloaded the vst and set up the audio in and out from the murf.
The problem is the vst is controlling the pressets on the voyager when i change the pattern. I cant seem to get the murf to run on a different midi channel either, ive tried lfo and freq left position stomp switch pressed power on ect and it doesnt work :(
Also does the vst run in 64bit applications?
If anyone could help that would be great
Monocoque
Re: Midi murf midi problem
Post by Monocoque » Tue Dec 03, 2013 12:58 pm
Solved what was wrong
Stupidly running the midi from the voyager with no clock oops :lol:
