Hi !
It could be me lacking in knowledge of operating an analog synth but I think there may be something wrong with my Sub Phatty.
If I turn up the gain of osc 2 in the mixer section, with all the other sources set to zero, I clearly can hear some noise blended with the signal. The same problem when only the noise source is turned up, but then osc 2 blends with the signal. I can hear osc 2 de-tune when I turn the frequency knob of osc 2 while it's gain is set to zero.
I hope this isn't a faulty circuit...
Greets,
Michael
Sub Phatty Noise source/Osc 2
Re: Sub Phatty Noise source/Osc 2
I've been further testing my Sub Phatty and it seems that when I use my Sub Phatty without the software editor opened, the problem disappears...
The problem reappeared, even though the software editor wasn't open, so it has nothing to do with that. I've reset all of the hidden parameters but without succes. I guess this isn't hardware related as the synth behaved flawlessly yesterday...
Does anyone might have an idea of what's happening ?
Thanks in advance !
Greets Michael
Thanks in advance !
Greets Michael
