Just bought my murf 3 days ago..using it with my drum machine.
I don't understand why the drive knob has no effect at all.the drive light just keep red.
Do i miss something here?
Sorry for my english,i'm from indonesia.
Thank you.
Darman.
Murf drive.
Re: Murf drive.
The signal from your drum machine is probably too high, try backing off the output at the drum machine.
Re: Murf drive.
I put my drum machine level very soft,the drive's light goes green and when i turn the drive knob,still not fuction at all.
I try with my other synth (soft level),but the drive knob still not respond.
Thank's for the replay.
Re: Murf drive.
Send your drum machine through a mixer and out via an Aux send to get the levels down to a 'normal' level.
Selamat Tingal,
Stephen
Selamat Tingal,
Stephen
Re: Murf drive.
yesman wrote:The signal from your drum machine is probably too high, try backing off the output at the drum machine.
yes i did,it's almost zero,light goes green but the drive knob still no effect.
Re: Murf drive.
Vsyevolod wrote:Send your drum machine through a mixer and out via an Aux send to get the levels down to a 'normal' level.
Selamat Tingal,
Stephen
may be the signal from my drum machine is not the problem,its low enough.
just the drive knob isn't respond anything.
thank you for replay.
terima kasih
darman.
Re: Murf drive.
What happens when you run another instrument through it? I sometimes get confusing results when I patch other electronic gear through my Foogers.
Stephen
Stephen
Re: Murf drive.
[quote="Vsyevolod"]What happens when you run another instrument through it? I sometimes get confusing results when I patch other electronic gear through my Foogers.
Stephen
Just the same when i use with my drum machine,I cant do anything with the drive knob.
I'm new with electronic but in my short experience,i guess it depends on many aspect such as the character of the pitch,rhythm,melody and harmony that we apply to it.
Darman.
Stephen
Darman.
Re: Murf drive.
It's also possible that you have a defective unit.
I'd write to Moog, explaining your situation as thoroughly as possible and I'm sure that they'll have a great response for you.
Stephen
Stephen
Re: Murf drive.
I call tech.support in Moog music yesterday & kindly he ask me to send the unit back to the dealer where i bought.
They will repair or change it with another unit,thats what he said.
Thank you Stephen.
Thank you Stephen.
