Minitaur VCA Envelope Release Time is very short
timemaster
Post by timemaster » Fri Sep 06, 2013 2:25 pm
My Rev 2 Minitaur has very short VCA Envelope release times. Specs list it at up to 30 seconds, but mine is more like 1.5 - 2 seconds timed with a stopwatch.
These are my settings;
VCA & VCF Envelopes
A= Min
R= Max
S= Mac
Cutoff = wide open
Res = 0
EG amount = 0
Anyone else have this , and is there a fix for this?
From the Minitaur specs
•VCA EG Decay/Release – Sets both the decay time to the sustain level and release time of a Minimoog-Style ADSR Envelope Generator used to modulate the VCA. Time ranges from 1 msec to 30 seconds. The Release segment of the EG is enabled by the Release On/Off switch.
Animoog, Filtatraon, Minitaur ( firmware V2.0) , Minitaur Editor ( V2.0 ), Logic Pro 10.0.7, iConnect MIDI 2+, iPad 4, OSX 10.9.5
till
Re: Minitaur VCA Envelope Release Time is very short
Post by till » Mon Sep 09, 2013 5:10 pm
It isn't that short on mine, but way more then 10 seconds here.
But you know about the different knob modes that might fool you thinking you are at the max release/decay?
And you know about the possible different setting for decay and release envelope stages of the newer firmware versions?
Here the manual addendum for this function:
DECAY/RELEASE CONTROL
REV 2 introduces a new operational mode for the Envelope DECAY/RELEASE knobs.
DECAY AND RELEASE MODES
To toggle between Mode 1 and Mode 2 press and hold the RELEASE switch for 1 second. The RELEASE switch LED will blink one time to indicate Mode 1, or two times to indicate Mode 2. (The selected mode is remembered on power-down).
MODE 1 - Control of DECAY and RELEASE functionality is linked.
MODE 2 - Turning the DECAY/RELEASE knob by itself adjusts DECAY time. To adjust the RELEASE time, press and hold the RELEASE switch while turning the DECAY/RELEASE knob.
NOTE: The Release On/Off function is now toggled when the panel button is released.
timemaster
Post by timemaster » Mon Sep 09, 2013 6:14 pm
Thanks Till!
Changing the Mode seemed to jog the minitaur out of it's problem state.
My Minitaur now behaves better, about 10 second release max, with both release and decay set to max in either of the 2 modes
mydni
Post by mydni » Mon Sep 23, 2013 4:12 am
Same here my release time is max 10s...
I really would like to know how to reach the 30s that is mentioned in the manual.
Anyone ?
Thks
