LP Stage II update
Everything Phatty.
JanGeerts
LP Stage II update
Post by JanGeerts » Fri Jul 12, 2013 10:29 am
I just got a LP Stage II, and would like to update it. I've dowloaded the proper files, but when I follow the instructions, the LP just hangs. When I reboot it, it is on the OS it was in.
Any suggestions?
best
Jan
JanGeerts
Re: LP Stage II update
Post by JanGeerts » Sun Jul 28, 2013 7:25 am
OK, apparently either a tough question or a badly posed one. I asked it via the tech mail contact and no answer there either.
Jan
Amos
Post by Amos » Sun Jul 28, 2013 1:12 pm
what sort of MIDI interface are you using? if it has drivers, are they up to date? what kind of computer and operating system?
in general, this means that something about your MIDI system isn't doing right, or the update would work.
If you're using USB directly to the LP, make sure it's not through a hub.
JanGeerts
Post by JanGeerts » Tue Jul 30, 2013 4:07 pm
It's a stage 2, so I'm using usb, not through a hub. I am experiencing other issues now, see different thread
What's the experience here on contacting tech support? I've got zero response, and it's more than two weeks now, since I asked the question through contact form.
Jan
