It's a Moog Source, with some sort of modification done to it. Inside is a small circuit board that looks to be added on more recently. This is connected to various pieces inside. There's a total of 12 switches that are drilled into the faceplate. Some of the switches appear to be broken inside as they do not "switch" in either direction, and several are completely loose and wiggle.
When I power it on, all I get out of it is a low drone flat-line sound, and nothing else. All of the touch surface responds, but not a single thing changes the sound at all.
I want to attempt a repair, but I really don't know where to even start. I was thinking of removing the add-on board all together, but it is wired into a chip that has pins bend out from it and wires soldered to.
I have some experience in fixing that hardware or replacing parts, but I don't have tools to test chips or boards or anything like that. My only recent experience was replacing 3 divider chips in a Realistic/Moog MG1 a few years back. That also was a clean out of all the old black tar foam.
Anyone out there that could give me some starter pointers, thanks! I have all sorts of pictures, so if there's anything you need to see, just let me know and I'll post what ever is needed.
Thank you all in advance.
