sustain pedal for Opus 3, anyone have a source for one ?
I'm looking for the sustain pedal that works with the Moog opus 3. FYI, I once paid someone to make me one with the proper (skinny non standard) jack and a standard square sustain pedal, it did not work.
- Portamental
Re: sustain pedal for Opus 3, anyone have a source for one ?
Open up your converted pedal (with a 3/16 TRS plug), connect the tip wire and the ring wire to the switch, leave the sleeve wire unconnected.
If your pedal is normally closed, it will be a sustain pedal. If it is a normally open pedal, it will be an anti-sustain pedal (it will cut the release time to zero).
