What does "pressure" correspond with in Logic Pro 8?
cosmigonical
Post by cosmigonical » Wed Apr 24, 2013 8:30 pm
In the pot mapping I see that there is "pressure", is this the same as "channel pressure" in Logic Pro 8?
expoobident
Re: What does "pressure" correspond with in Logic Pro 8?
Post by expoobident » Mon Apr 29, 2013 11:00 pm
Yes. The channel pressure in logic does correspond to aftertouch on keyboards, but channel pressure is the amount of pressure for the entire channel. If you have a polyphonic synth the channel pressure in logic will average the amount of aftertouch on all the keys being pressed rather than each having their own value, but since the voyager is monophonic you don't have to worry about that.
