There seems to be some sort of MIDI port conflict between the two. If I load up Editor without Live running I can select Minitaur from the input and output under the MIDI setup from the "Under the Hood" page and the firmware version changes from ??? to 2.0.0 and everything works in terms of presets changing Editor etc.
However, when I then load Live I can't use the Minitaur as the ports are disabled (as Live indications in orange as below)
If I don't have the Editor open then open Live sees the Minitaur and I can play notes via a midi keyboard and record automation from the hardware no problem. If I then try to open the Editor the firmware version shows as ??? (even after changing the input/output to something else then back again) and nothing works.
This all means I can't have both Live and the Editor open at the same time, which is obviously a critical problem as I need to be able to browse and save presets.
Any ideas what could be up?
Needless to say, I've erased and updated the v2.0.0 firmware several times, and tried many power cycles of all elements of my system.
I'm not 100% sure what the Track/Sync/Remote settings should be on Live's midi preferences page but i've tried all combinations for the Minitaur and had no luck.
