restlessboy
Post
by restlessboy » Wed Apr 03, 2013 4:32 pm
Hello again forum,
I think I read somewhere that you can stop the mod wheel from flashing in time with the LFO, but I can't see how to do it - have searched the manual but can't seem to find it. Can anyone help?
It kind of gets on my tits.
thealien666
Post
by thealien666 » Wed Apr 03, 2013 9:03 pm
Taken from the Moog Music web site:
This is a custom modification which drives the pitch and mod wheel LED brightness directly from the LFO triangle wave output, giving you an accurate and dramatic visual representation of the LFO voltage level at any moment.
It comes with a small internal switch which allows you to set the wheel lighting back to "always on" in case of visual over-stimulation.
Portamental
Post
by Portamental » Thu Apr 04, 2013 1:08 pm
You don't like it? A matter of taste I guess... I paid big bucks to have clear plexiglass mod wheels flashing at the LFO rate installed on my Prodigy.
Ledbetter
Post
by Ledbetter » Thu Apr 04, 2013 9:05 pm
Caveman solution--black vinyl tape on the rim?
thealien666
Post
by thealien666 » Fri Apr 05, 2013 12:42 am
So, restlessboy, have you found that internal switch yet ?
thealien666
Post
by thealien666 » Sun Apr 07, 2013 12:58 pm
Well, I guess restlessboy might have electrocuted himself while looking for that elusive internal switch ?
I hope he didn't turn out blind by staring too long at those super bright flashing wheels ?
Ledbetter
Post
by Ledbetter » Sun Apr 07, 2013 1:56 pm
Even without flashing, the wheels are a little too bright for me. My Voyager lights up red. I'm going to tape the rim with red vinyl tape and see how it looks.
Good luck to the OP, sorry I can't help. Call Moog?
thealien666
Post
by thealien666 » Sun Apr 07, 2013 2:22 pm
@restlessboy
In case you didn't see my original response, here it is again:
There's a small internal switch which allows you to set the wheel lighting back to "always on".
restlessboy
Post
by restlessboy » Sun Apr 07, 2013 6:26 pm
Sorry! Been away from the forum for a few days. So this internal switch... how exactly do I get to it? Remove the back panel or some other way....? I did look!
thealien666
Post
by thealien666 » Sun Apr 07, 2013 6:56 pm
My guess would be underneath the mod wheel assembly, on the LED pcb itself.
You could send Moog an email asking them.
The info I got is from the Moog Music web site under "factory mods".
Prime NL
Post
by Prime NL » Sun Apr 14, 2013 3:52 am
I finally found a shop who can send and ship this mod....but my question is.....can this be done easily by myself....or is it really necessary to ship my Voyager to Moog for this modification.....?
Any calibrations or something to be performed for this...?
thealien666
Post
by thealien666 » Sun Apr 14, 2013 2:23 pm
Just send a quick e-mail to Moog Music support team, they'll probably tell you all about it...
restlessboy
Post
by restlessboy » Sun Apr 14, 2013 5:28 pm
I got the following e-mail from Moog when I asked:
The flashing wheel switch is located underneath the pitch and mod wheel module. To access it:
*Remove the 2 long screws from the front of the wheel module
*Pull out the wooden block and carefully lift the module up and out
*Look for a small board that is attached to the corner of the larger board underneath. It should have a small black and silver switch. Flip the switch to the opposite position.
*Reinstall the module, wood block, and screws.
Sounds easy enough. Haven't got round to trying yet. Will take some pictures once I've opened it up, should help anyone else interested in turning it off.
thealien666
Post
by thealien666 » Sun Apr 14, 2013 9:03 pm
I would add; be careful when re-installing the mod-wheel assembly in place, to make sure that it is inserted properly in the groove in the wood casing at the top back. Otherwise the two openings for the screws on the top front won't line up properly with the holes in the wood. The original Minimoog D has the same mod-wheel assembly design also.
And thanks for the follow-up.
JamesWoods
Post
by JamesWoods » Wed Apr 17, 2013 8:13 am
Portamental wrote:You don't like it? A matter of taste I guess... I paid big bucks to have clear plexiglass mod wheels flashing at the LFO rate installed on my Prodigy.
Why are you not trying another model ?I know LFO is something related to status but not reasonable ,so you can try other brand.
Singing Lessons London
