Model D mp3 samples…
I promised to create some samples of my Model D since I think it sounds more alive and fatter then the Voyager. I’m not complaining, I love my MMV AE. Here are some mp3 samples all recorded without effects.
I’m afraid my Model D is a bit sick right now and she will soon be gonging to the doctor for a check up but I managed to create some sounds.
xsynt_filter_sweep
xsyn_bass
xsynt_ResoBass
xsynt_JazzBass
Kind regards
Demokid
xsynt_filter_sweep
xsyn_bass
xsynt_ResoBass
xsynt_JazzBass
Kind regards
Demokid
Gearlist: Andromeda A6, Emu E4XT Ultra, Korg MS20, Minimoog Model D (incl.MIDI), Minimoog Voyager AE, Roland Jupiter-8 (MIDI), RE-301, Prophet~5 (Rev3.3 incl MIDI), Poly Evolver Keyboard, Pro~One, Prophet 08, Synthesizers.com Custom Studio-44
Well… I get more “oomph” (puchier sound) out of the D then the MMV. The envelopes seems a lot tighter (faster) on the D, the oscillators seams hotter (don’t know how to explain it).
One sawtooth on the D has a lot more feeling then one on the MMV. If you make a basic Minimoog sound with three VCO’s on the MMV and make the same sound on the D with 2 VCO’s the D still sounds fatter, warmer and punchier.
I think the only way to experience the difference in the sound is to play with both on the same time. I will not sell the D since I always use it for deep hard basses and fat leads.
But the MMV is still a great sizer and has more stability better MIDI and a lot more fun things to play around with.
Regards
Demokid
Regards
Demokid
Demokid,
I second every word.
I might to add, that I like to have a synth in this class with me on stage. And I am to afraid my Mini could break down because of this. So the Voyager is the closest thing to the Minimoog. And the added new modulation possibilities make it nearly a tine Moog Modular.
Using the feedback loop on the Voyager and only use the single filter output will improove the Voyager's sound in terms of sounding like the Minimoog. But I only did so for some testing only.
Till "Qwave" Kopper
[url=http://launch.groups.yahoo.com/group/Squarewave/]Squarewave Group[/url] member "waldorfian_qwave"
Till "Qwave" Kopper
Demonkid,
I understand when you say "puchier" and the envelopes seems a lot tighter.
But when you use terms like "sawtooth on the D has a lot more feeling" and warmer. Things you could say about a human being I get lost.
How does the Sawtooth have more feelings?
Is there a more technical way to explain?
Demokid - these are nice sounds. I was going to see if I could (somewhat) match them but I've actually been writing music rather than messing about with gear.
I'd like to have a go, though, and it would help a lot if you could give a brief patch description of each - number and shape of oscillators, basic env / filter settings. It doesn't have to be exact, just a frame of reference. Tx
Hmm… I actually don’t remember the settings. I know I used all three VCO’s, probably (32,16,16) or (32,16,8). I think I used sawtooth, pulse-1 and SawTri waves. I did some tweaking in real time of e.g. resonance, cut-off and Filter Decay.
I usually don’t like to make demo samples of sizers since it takes time from my composing but this was actually really fun.
Suthnear:
I don’t think you have to work so hard to copy my sounds… just have fun and create some cool sound on your MMV.
Kind regards
Demokid
Suthnear:
Kind regards
Demokid
Thanks DK - I thought you'd used all three but because the voyager's waveshaper is continuous it can take quite a while to dial in the 'right' combos. Might get some time tonight...
ikazlar - we are all but the sum of our preoccupations
for me, anyway, this is an exercise in careful listening and I hope that I will come out of it knowing just a little bit more about my voyager than I do now.
Hi Demokid,
Thanks for the nice samples from your Model D.
That helps me to make the MMV sounds like a Model D.
I have tried to match your first sample "xsynt_filter_sweep" with my Voyager, recorded from left-out only.
xsynt_filter_sweepMMV
Greets
Auratune
Greets
Auratune
