Anyone else noticed this anomaly? I use FM quite a bit and this makes patches annoying/unusable unless you want a slide effect (ie most of the time)!
Side question. When using Osc 1 or 2 as one of the programmable mod sources is that an exp fm source? Manual doesn't specify. Assume it is as freq and waveform adjustments behave as expected.
