July 2005 Patches
LWG
July 2005 Patches
Post by LWG » Tue Jul 12, 2005 1:31 am
Korg Trident Resonant Lead
The following is a Voyager-adapted version of a patch which appeared as part of the factory set for the Korg Trident Mk II (synth section).
Works fine with a splash of delay and a bit of reverb (adjust reverb to add ambience, yet retain presence).
Oscillators:
Octave: Osc 1-4', Osc 2-4', Osc 3-4'
Wave: Osc 1-50%Squ, Osc 2-Saw, Osc 3- Tri
Frequency: Osc 1-n/a, Osc 2- 0 [slow detune (-2)], Osc 3- +2 (+40)
Mixer:
Level: Osc 1-8 (215), Osc 2-8 (215), Osc 3-0, Ext-5 (128), Noise-0
Filter:
Frequency-1.2Khz (165), Spacing-0, Res-5 (122), KB-5 (122), Mode-LP/LP,
Envelope Amt- +.7 (+20), Pole Select A/B- 4-Pole/4Pole.
Filter Envelope: Attack-0, Decay-65mS (137), Sustain 4.8, Release-5mS.
Amplitude Env: Attack-0, Decay-0mS, Sustain-10, Release-5mS, Gate-KB.
Mod Wheel Bus: Source-On/Mod, Dest-Filter, Shaping-Filt Env, Amt-6.4
Pedal Bus: Source-Tri, Dest-Wave, Shaping-Filt env, Amount-2.2 (039)
Sync: Off, 3-1 FM:Off, 3KB Control: Off, 3 Frequency: Low
LFO Rate: 1.2 Khz (057), Lfo Sync-Off
Glide rate-5, Glide-Off, Release-On
Key Mode: Low Note
Trigger Mode: Multiple
Bend amount: +/- minor 3rd
Master Volume: 6.8
Cabling: Mixer feedback loop, Right channel plug optional.
Regards,
LWG
