EMwhite wrote:Remember how special you felt when something was published as DDD?
Bend over kid, I have something I want to sell you...
Yeah, I remember those days.
There are a couple of good questions that you ask here. Yes, you total overall sound will be of highest quality IF you maintain a completely analog chain, using only the most expensive gear. Once you convert it to digital to record, the higher quality AD convertors will retain the most of that analog sound. The cheaper ones will deteriorate it the fastest.
Then there is the whole raison d'être for analog synths in the first place. And it's all about how control voltages modify an oscillator, a filter, a VCA, etc. And of course the (potentially) rich creamy sound of the oscillators in the first place. Be it known though, that some digital emulations of analog waveforms sound superior to the cheap low quality analog sounds. Take the DSI Polyevolver for example. The analog circuits are not of the expensive high quality variety. So even though you have a partially analog waveform, it still sounds like shiite. Then again, the high end Buchla oscillators do not have that warm sound that makes you tingle all over like the better Moogs do.
Like has been said, use your ears and go for the best you can.
Stephen
