Hi all
I am calibrating my Moog 55. One of the 8 EGs is completely different from the usual ones. It is a very early version, with more components / caps, no trimpots at all, no possibility of calibrating offsets, glitches etc. It is dated May 3 1968 on the yellow tag. I have not found any clue or schematics about it...
The problem is, it does not work properly: with all of the pots counterclockwise, at the minimum, the sustain works but there is asmall amount of slow attack. When I raise the attack pot (T1) until 2 ms, the envelope returns snappy, but the sustain is steady at the maximum. At higher values of the T1, the attack works as it should.
Any help is appreciated
Ciao
Fernando
Moog 911 EG mistery!
- Kevin Lightner
Re: Moog 911 EG mistery!
I first replied to ask if there were 100 ohm resistors inline with the pots for times (A,D,R), but in looking at your photo, I think there are.
You might check to see if the attack pot is ok by shorting it with a jumper or using an ohm meter.
Other than that, you might consider adding the 3 trimmers later models have.
- thealien666
Sounds like maybe a case of a dirty/worn Attack Allen-Bradley pots near, or at minimum position (easily checked with Kevin's suggestion of shorting out the pot) ?
Kevin,
I shorted the T1 pot, but nothing changes.
I guess something was changed (the Philips cap is not original, IMO) but without a schematic diagram it is very difficult to understand what...
