Sync lfo to arpeggiator
Is it possible to internally sync the lfo rate to the arpeggio? Without using an external MIDI device, that is.
Re: Sync lfo to arpeggiator
Stage or slim? If a stage roll back the OS to pre 0S3.0. Rolling back to before 3.0 requires a $30 usb debugger since the bootloader was changed when the OS went 3. That function was axed for other features. There are some threads about it with some disappointed users.
And if I remember correctly the ARP synced to the LFO not the other way around. You could create the same thing as the other way around in a static sense, but with the way that it was if you wanted to change the LFO rate in relation to the notes it was weird.
