ikazlar
Post
by ikazlar » Thu May 12, 2005 1:57 am
Does anyone here uses DI boxes with the unbalanced outputs of synths (Voyager or others). If so, did it solve any problems?
Ciao
monads
Post
by monads » Fri May 13, 2005 11:51 am
What sort of problems are you referring to? I don't have a DI box but I did think of picking one up (Manely mono Tube DI) to warm up some sounds.
Qwave
Post
by Qwave » Fri May 13, 2005 4:15 pm
I used them while playing in a band through a long multi-core to the in house mixer. And the ground lift sometimes helps if you got some ground loop problems on stage.
Till "Qwave" Kopper
[url=http://launch.groups.yahoo.com/group/Squarewave/]Squarewave Group[/url] member "waldorfian_qwave"
ikazlar
Post
by ikazlar » Fri May 13, 2005 5:05 pm
I have a little bit of noise in the studio. I have checked ground loops and the like.
I thought about running unbalanced signals into DI to turn them to balanced. Maybe this will solve the problem. I have checked about DI boxes and probably pick up one from Manley.
monads
Post
by monads » Sat May 14, 2005 1:53 pm
Yea I here good things about the Manely. Others are Radial Engineering (these ones might just be what your looking for) Avalon Design, TAB Funkenwerk, etc. Let us know how it goes.
