Post
by Assar » Tue Jun 12, 2012 11:23 am
Ok, some basic things.
I'm use Cubase 4 but I guess those basic functions still is the same.
You are probably listening to the sound from your LP directly through you sound card, without passing through Cubase (the application).
Make sure your sound card doesn't send the signal directly from the audio input to the monitors. It should pass through Cubase.
How you do that is depending on your sound card.
Moog audio out -> Sound card line in.
You should now here nothing, until Cubase is set up.
In Cubase:
- Go into VST Connections menu and add a mono input named "Phatty". Route the used audio in on the sound card to the mono input.
- Now, make sure the "Phatty" input channel is visible in the mixer (F3). Play you LP and check there is a signal coming in.
- Add an audio track (mono). Select "Phatty" as track input in the Inspector. Make sure the little speaker on the track is lightened up, then the monitoring is on. Play you LP and check there is a signal coming in to the track. The sound should now be routed from your LP to you sound card, to the Cubase mono input you created, to the audio track and out the the (probably) stereo output, to your sound card and to your monitors.
You need this routing to make it work, that's why you should make sure the signal is not sent directly from you sound cards input to the sound cards outputs.
- Play your LP and adjust the input level.
- Now you should be able to
If you want to use MIDI in Cubase:
- Make sure your LP is properly connected to some MIDI interface in your computer.
- Add a MIDI track in Cubase. Select the used MIDI input as track input in the Inspector. Select the used MIDI output as track output in the Inspector. Make sure the little speaker on the track is lightened up. Play you LP and check there is a signal coming in to the track (little meter before the track).
- Record some MIDI, or define a MIDI clip manually. Play it back to your LP. You should now be able to record the audio the MIDI track is playing on you LP.
Did that help???
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
