LFO > pitch > perfect octave
Everything Phatty.
typhy
Post by typhy » Mon May 28, 2012 9:46 pm
LFO source: Square
LFO dest: pitch
how can I set the amount to be a perfect octave?
what should be the exact number in precision mode?
stiiiiiiive
Re: LFO > pitch > perfect octave
Post by stiiiiiiive » Tue May 29, 2012 3:57 am
I don'thave my Phatty right here but to me the best way is to listen.
The only detail is that as LFO is bidirectional (I think so at least...), the note you'll be playing when pressing say a C key will be a F#, i.e. half an octave. If you set the LFO amount to play a two octave interval, that is not true anymore and all your problems are gone :)
Assar
Post by Assar » Tue May 29, 2012 8:19 am
The LFO is not bidirectional when you use square source.
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
Sir Nose
Post by Sir Nose » Tue May 29, 2012 10:35 am
typhy wrote: what should be the exact number in precision mode?
Precision mode is pretty precise. I am pretty sure it will differ slightly from phatty to phatty. Use your ear or a tuner to find the precision mode value for your particular phatty.
Mr Shave
Post by Mr Shave » Wed May 30, 2012 6:53 pm
A good way to do it with using your ear and no tuner...
Mod wheel down, press a note.
Mod wheel up, press the same note but an octave lower.
Adjust amount knob to get pitch closer
repeat until you cant hear a difference.
Sir Nose
Post by Sir Nose » Wed May 30, 2012 10:45 pm
Mr Shave wrote:A good way to do it with using your ear and no tuner...
Nice :)
