Think I fried my Frexbox :(
Pantherairsoft
Post by Pantherairsoft » Sun May 06, 2012 3:16 pm
I was experiencing some unwanted noise in my signal chain so started the process of isolating each pedal from my pedalboard one by one...
It came the turn of the Freqbox. I plugged in a Moog PSU and powered up. There a strangle whining noise, not from the pedal but from the PSU... Then I got a static/electric shock from the cable jacks connected to the Freqbox! I quickly powered down and changed to another Moog PSU (I have 5 as I own 5 foogers!). Thankfully no noise.
Freqbox powered up and bypass let's the signal through fine. Turn the pedal on and my clean/dry signal is there, BUT none of the Freqbox/VCO sound. It basically seems the faulty PSU has killed the VCO!?
The mix knob on the pedal now basically blends from dry to silent! :(
Shep on Bass - My website & blog
Bitnormal Records - Netlabel specialising in electronica
KADE - Improvised live electronica
Patient Zero - International hip-hop & electronica collaboration
Re: Think I fried my Frexbox :(
Post by EricK » Sun May 06, 2012 9:02 pm
Does the level light reflect the input signal or is it constantly on or off?
Pantherairsoft
Post by Pantherairsoft » Sun May 06, 2012 10:19 pm
Hey,
I'll need to check when I get back to the studio but I 'think' it was reacting normally. It may of been always on (certainly not always off) but I do think it was reacting my input fine.
jeepo
Post by jeepo » Thu May 10, 2012 1:39 pm
I've had my freqbox cut out like you described a couple times. All I did was cycle the power and all was normal again. I haven't had that problem since I moved from that house, so I think power issues can do weird things to the freqbox, but mine's not fried, and hopefully yours is not either.
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
Pantherairsoft
Post by Pantherairsoft » Wed May 23, 2012 5:10 pm
Seems it was some damaged components caused by a failing power supply.
This has been repaired and it now working full bore again...! WIN. Good day to receive a repaired big of Moog gear... makes me feel like I was celebrating Bobs birthday :)
