New Voyage SoundEditor update for MAC
soundt
Post by soundt » Mon Mar 28, 2005 9:30 pm
Hi-
There is a new update for the MAC Voyager SoundEditor available now. Soon it will be available from Moog Site. Right now you can download it from:
wwww.soundtower.com/moog/mac/voyager.sit
Here is a brief description of new features. For more information please check the updated manual that comes with the setup.
Moog Voyager Sound Editor Version 1.06
CHANGES AND ADDITIONS:
MAIN BANKS Window:
Additions:
Selection of multiple items in the Library by using "Shift+Arrow" keys.
Drag and Drop selected multiple presets from one librarian category to
another. Drag and Drop selected multiple presets from library to Voyager
Bank. When dropping Presets to Voyager bank there is an option to
transmit and replace Voyager presets automatically. Dropped multiple
Presets will replace the selected Preset in the bank and the equal
number of Presets with consecutive numbers.
Example:
1. Select 5 presets from Library category.
2. Select Preset No 003 from the Voyager's Bank
3. Drag 5 selected Presets from the Library category and Drop them into
the Voyager's Bank.
4. From the warning dialog that pops up select "OK" and Presets 003 to
007 in the Voyager's Bank will be replaced. If you select "NO" then
Presets will not be transmitted to Voyager but they will still replace
Presets 003 to 007 in the editor. Selecting "Cancel" will cancel the
operation.
Copy and Paste of multiple Presets in the Librarian has been also added.
You can copy and paste between categories or paste multiple selected
Presets from the Librarian to the Voyager's bank in similar way like
using drag and drop described above.
"Select All" function under Library menu has been added. When selected
it will select all Presets in the current librarian category.
PRESET GENETICS
Additions:
Single Parameter Adjustment.
This function can change one of the Preset parameters in a whole
Voyager's Bank. Let say you want to change Volume or KEYBOARD MODE in
all Presets in the bank - now you can do it with a just one click!
In the Preset Genetics window you can select any Preset parameter and use
slider to set a new value. When you click OK button the editor will
generate The Kids bank. The Kids bank will contain all MOMMY's (Voyager
Bank) Presets with modified selected parameter.
Under Preset Genetics File menu you will also find a new function:
"Replace Voyager Bank with The Kids Bank". This function will replace
editor's Voyager's bank with modified Presets (The Kids). When using
this function you will be also presented with an option to send this
modified bank to the Voyager. This function will also replace MOMMY's
bank and you can continue to modify some other Preset parameters if you
like.
PLAYING COMPUTER KEYBOARD
Now you can audit Voyager sounds by pressing computer keys to play notes
on Voyager synth.
Key assignment:
Letters:
u and i - increase and decrease note velocity value (0 to 127)
o and p - increase and decrease octave (-2 to 2)
z C
s C#
x D
d D#
c E
v F
g F#
b G
h G#
n A
m B
SPACE - All Notes OFF
Thank you for your support! We hope you enjoy new editor's features.
