I have a Voyager RME, running V3.5 OS. I've noticed the oscillator sync does not seem to be behaving as it should; when sync is turned on, making any changes on osc 1 does not affect osc2. When adjusting the freq of osc 2 it just seems to behave as if osc sync is turned off (albeit with a wider freq range).
I've tried it on a number of different presets and the same seems to happen on all of them. It's a bit strange that no matter how osc 1 is set, it doesn't affect osc 2 when sync is on? I'm certain this is wrong.
I've contacted Moog support, but was wondering if anyone else has any ideas? Osc sync is one of my favourite techniques, so quite eagre to get this solved...not to mention the warrantly is almost up.
Dan
Osc sync problem
Osc sync problem
My tunes - soundcloud.com/warbatron
Re: Osc sync problem
Any updates from support on this?
Yep, after making a video of the problem, Moog have advised that the osc sync pulse is not working. I'm dissapointed as I thought this synth was built like a tank. Good job it happened within the warranty.
I was impressed with the support though...very quick responses, and very apologetic.
