Hey everyone
Just got my slim phatty yesterday, Ive avoided most of the major pitfalls; updated the firmware & worked out how to send the midi clock so I can sync my Arp
one thing i have noticed is that, sometimes when I am recording the audio from my SP into logic all the other channels will go silent, Midi & Audio
the only way I have found to get around this is by Alt dragging the parts (copying them) to a new part an then they play again, but the previous audio an midi that was in the project just seems to be dead
has anyone else come across this?
thank you in advance!
Everything just goes silent in Logic?
Re: Everything just goes silent in Logic?
I know this sounds silly, and I don't know how much experience you have, so forgive me if I just ask if you may have accidentally hit the "solo" button besides the "record" button?falloutsoldier wrote:Hey everyone
If all other voices are mute (and you didn't touch the solo button), is the solo button yellow? If so, somebody else has switched it on:
Download and start midi monitor from snoize.com (it's free), set it to watch your LP midi port and see if the LP transmits anyhting except notes. If it transmits control changes, check if Logic is mapped in a way that this control change means "solo part". Play the keyboard, push all buttons, turn all pots, see if and when the track is soloed and try to isolate the command.
If you have found the command, then it's tricky - do you have other input devices? Is it possible you have accidentally used the "midi learn" command to map this command to solo a part? Don't delete the command unless you are absolutely sure it is not used and will not be used by other input devices.
Good luck!
