Multi-Moogerfooger power supply
ClintAu
Post by ClintAu » Thu Jun 16, 2011 5:05 am
It would be great if there was a power supply that could power multiple Moogerfoogers. It's kind of ridiculous to cart around a whole bunch of wall-warts.
I'm not sure from an electrical engineering perspective where it is possible or wise, but sure would be handy!
Moogerfoogers, Minitaur, Win10. Previously: Slim Phatty, Voyager
toryjames
Re: Multi-Moogerfooger power supply
Post by toryjames » Thu Jun 16, 2011 1:23 pm
Yes, there have been quite a few members asking about this in the past. Apparently, noise becomes a problem when powering multiple MFs from a single power supply.
Post by EricK » Thu Jun 16, 2011 1:34 pm
How much power do the Foogers draw as opposed to the original Moog modules?
Surely noise wouldn't be an issue if it were properly designed, right?
seank
Post by seank » Thu Jun 16, 2011 3:38 pm
Voodoo labs pedal power 2 plus. No noise, powers every moogerfooger at once and has an extra 3 prong outlet for plugging in whatever you want. Highly recommended.
Pantherairsoft
Post by Pantherairsoft » Thu Jun 16, 2011 3:41 pm
Gigrig modular power supply - http://www.thegigrig.com/acatalog/PS_Mo ... ystem.html
The only system I know that will power them as well a everything else! I know - my liv set up is around 20 effects including 4 MoogerFoogers, everything powered noise free by the gigrig.
Set back to MoogerFoogers is you need a Gigrig virtual battery (to isolate the pedal) AND a line6 adapter (to change plug size & polarity) for EACH fooger.
Again, expensive but amazing.
Daniel, the man behind gigrig is a top bloke and goes the extra mile to get the set right for each person. Even personally modded an adapter for a pedal I had that wouldn't play ball... And didn't charge me a penny extra for the work.
Shep on Bass - My website & blog
Bitnormal Records - Netlabel specialising in electronica
KADE - Improvised live electronica
Patient Zero - International hip-hop & electronica collaboration
ClintAu
Post by ClintAu » Sat Jun 18, 2011 1:27 pm
Thanks for the tips, everyone - I'll check out some of these third-party power supplies.
joe_moog
Post by joe_moog » Wed Jun 22, 2011 1:48 pm
So...I started with one Moogerfooger and now I have a whole Moog arsenal. So much so that I've pretty much gone from guitar obsession to synths. I've relocated the MFs from the Pedaltrain board, where they were being juiced by the Pedal Power Plus. Now, I'm trying to build a rack-based, all-in-one poly synth beast. I'm thinking about building something based off this to supply the MFs once I have a suitable enclosure:
http://www.geofex.com/article_folders/spyder/spyder.htm
Sub 37 • Voyager Select Whitewash/Lunar White • VX-351 • Little Phatty Stage II w/CV out • Slim Phatty (x3)
MF-101 • MF-102 • MF-104SD • MF-103 • CP-251 • MF-108M • MF-105M
Moog Pocket Protector
latigid on
Post by latigid on » Wed Jun 22, 2011 10:25 pm
You probably should look at this or this
https://taweber.powweb.com/store/magnetic.htm
Best of luck!
joe_moog
Post by joe_moog » Thu Jun 23, 2011 10:57 am
That's precisely what I'm using for mine! 8)
MichaelPeterTrowbridge
Post by MichaelPeterTrowbridge » Wed Oct 26, 2011 1:57 am
Would one be able to power 5 Moogerfoogers + 1 MP-201 with the Voodoo Labs Pedal Power 2?
mhuxtable
Post by mhuxtable » Wed Oct 26, 2011 8:25 am
definitely not.
check out the Cioks DC10.....you'd have to combine some of the outlets, but it'll power about 4 MFs.
Sir Nose
Post by Sir Nose » Wed Oct 26, 2011 2:04 pm
mhuxtable wrote:definitely not.
I'd have to go with their "Pussy Power"
The LED clit is just way too awesome.
mhuxtable
Post by mhuxtable » Wed Oct 26, 2011 3:48 pm
I'd have to agree! I almost got one instead of the DC10....
seank
Post by seank » Wed Oct 26, 2011 9:49 pm
MichaelPeterTrowbridge wrote:Would one be able to power 5 Moogerfoogers + 1 MP-201 with the Voodoo Labs Pedal Power 2?
easily done. i have my voodoo labs pedal power 2 plus powering all 6 moogerfoogers, cp-251, and slim phatty simultaneously. no noise. no issues.
Post by MichaelPeterTrowbridge » Fri Oct 28, 2011 12:07 pm
This is very good news! So all I need is the Vodoo Labs Power Pedal 2 plus 5 of these:
http://www.thomann.de/de/voodoo_lab_ped ... pprevr.htm
Right?
