What cable for mix out socket?
Call me dumb, but I'm a musician not an electrician. I don't understand the wiring diagram on page 14 of the OS manual where it shows an external effects pedal plugged into the mix-out socket. "Using a standard insert cable...". The "standard insert cable" looks to me like a cable with a mono jack at one end and two jacks, each with only one wire, at the other. Is this what it is? If so, where can I get one without having to buy a soldering iron? The patck leads I've seen, and those I have, all have a mono jack at each end.
Re: What cable for mix out socket?
It's the same as a quarter inch stereo (TRS) to dual mono (TS). The Hosa STP-202 is one such cable
http://www.novamusik.com/search.aspx?ty ... d=46&lbs=1
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
Thanks you sir! I ha
ve ordered one.
