Suggestion for the next OS update
Here are my suggestions for the next FW update:
- Increase the resolution of Analog Mode "Track" (in the current FW, zipper noise is noticeble before a stored value is traversed and the value is handed over to the analog pot)
- Increase the depth of Cutoff knob and filter EG amount, so that the filter can be opened wider (that would result in preset incompatibility, though...)
cheers,
kybernaut
cheers,
kybernaut
This is more of a visual change but it would be nice.
When using non-LFO related MOD sources (i.e. Filt. EGR, Osc. 2, Noise) it would be nice if the "LFO Rate" LED actually turned off, in addition, maybe when trying to click the "LFO Rate" you could even turn off the LED ring around the POT. I know this seems kinda pointless but it's just little things like that that sometimes initially confuse me (i.e. why can i modify this LFO if it can't actually do anything to the signal path in this mode) then it eventually annoys me!
Another thing that really bothers me is that the symbol for sustain in the Envelope section is a time based diagram and not an amplitude based diagram (seen here: http://www.flickr.com/photos/ecallender/223944188/)
vs
_
_
these are just random thoughts but seem to be things that a synthesizer newbie who just bought their very first synth (LP) might be confused about (or worse, misinformed in the case of the time vs. amplitude diagram)
vs
_
_
Seems safe to announce that certain controllers will definitely send and receive at 14-bit resolution in the upcoming OS release. Pitch Bend was already 14-bit I think... in the upcoming release the Modulation wheel CC will be 14-bit, as well as Filter Cutoff.
Using the Mod wheel to control filter cutoff, now allows VERY smooth tweaks to be recorded and played back via MIDI. It sounds amazingly better.
When I use S+H or noise as a mod source, if I press a button on the panel the "hold" stands for a longer time. Has anybody else noticed this? It's more evident with the noise.
It could be a hardware related problem or a software problem. I don't have any idea about how these functions are actually implemented. By the way, does anybody know? If it's a software bug a fix would be so nice
Sorry if I ask for current "problems" instead of new features but IMHO the LP worths it, like in the ad
Next OS For LPTE
could you "leak" a release date timeframe so I can get some sleep?
Signed,
Guarding My Matress Tag
Signed,
still in alpha testing
beta release tomorrow, we hope
actual release a week after beta, barring unforseen changes.
so realistically about a month.
hopefully sooner!
[edit]: Just to clarify, most of the super-fancy features we are discussing will take some real time to implement; we are putting them on our "version 2.0" wish list. There will be a firmware update soon, but it will be v1.03C with a few bugfixes and several new features, but nothing earth-shaking.
Unless of course you have a Voyager and an LP and think it would be earth-shaking to play them together, duophonically... you'll be able to do that.
hopefully sooner!
Firmware
thnx Amos :) man i gotta tell ya...the ability to add stuff to my LPTE totally rox my sox...its like getting new hardware for free :)
BRILLIANT DESIGN!
ps is the new LP Tutorial Video comin out soon? I could REALLY benefit from that i think :)
BRILLIANT DESIGN!
Re: Firmware
No offense - but is a tutorial really needed for something as easy to use as the LP?dlearyus wrote:ps is the new LP Tutorial Video comin out soon? I could REALLY benefit from that i think
“I have stretched ropes from steeple to steeple; garlands from window to window; golden chains from star to star, and I dance.” - Rimbaud
re:
yup calyx believe it or not i am a TOTAL newbie with these things. Amazing little box. I was hoping a basic tutorial might help me get past the presets. twiddling the knobs is lotsa fun fer sure but i know i havent even scratched the surface of this device yet.. :) i can use all the help i can get however minimal ;)
Re: re:
I'd suggest you pick up a copy of 'Power Tools for Synthesizer Programming' by Jim Aiken. It explains synthesis in depth (all forms, not just analog), including oscillators, filters, envelopes, LFO's, modulation and effects. The book is pretty comprehensive, and would make a great introduction for a newbie.dlearyus wrote:yup calyx believe it or not i am a TOTAL newbie with these things. Amazing little box. I was hoping a basic tutorial might help me get past the presets. twiddling the knobs is lotsa fun fer sure but i know i havent even scratched the surface of this device yet..i can use all the help i can get however minimal
You can check it out here:
http://www.amazon.com/Power-Tools-Synth ... 660&sr=8-1
Analogue Function
Thnx much GregAE I will def pick up a copy of that. Cheers m8 :))
http://www.amazon.com/Power-Tools-Synth ... 660&sr=8-1[/quote]
