Suggestion for the next OS update
Everything Phatty.
kybernaut_01
Post by kybernaut_01 » Tue May 29, 2007 3:56 pm
Here are my suggestions for the next FW update:
- Increase the resolution of Analog Mode "Track" (in the current FW, zipper noise is noticeble before a stored value is traversed and the value is handed over to the analog pot)
- Increase the depth of Cutoff knob and filter EG amount, so that the filter can be opened wider (that would result in preset incompatibility, though...)
cheers,
kybernaut
electrical_engineer_gEEk
Post by electrical_engineer_gEEk » Tue May 29, 2007 5:13 pm
This is more of a visual change but it would be nice.
When using non-LFO related MOD sources (i.e. Filt. EGR, Osc. 2, Noise) it would be nice if the "LFO Rate" LED actually turned off, in addition, maybe when trying to click the "LFO Rate" you could even turn off the LED ring around the POT. I know this seems kinda pointless but it's just little things like that that sometimes initially confuse me (i.e. why can i modify this LFO if it can't actually do anything to the signal path in this mode) then it eventually annoys me! :)
Another thing that really bothers me is that the symbol for sustain in the Envelope section is a time based diagram and not an amplitude based diagram (seen here: http://www.flickr.com/photos/ecallender/223944188/)
vs
_
_
these are just random thoughts but seem to be things that a synthesizer newbie who just bought their very first synth (LP) might be confused about (or worse, misinformed in the case of the time vs. amplitude diagram)
denoiser
Post by denoiser » Sun Jun 10, 2007 8:30 am
What about sending the "internal" 4096 values thru midi with NRPN instead the normal CC?
It's a pity having such a low resolution (128) on a real analog machine. You really notice the steps when recording and playing pot movements. Definetely it's not a nice thing :(
Post by Amos » Mon Jun 11, 2007 5:59 pm
Seems safe to announce that certain controllers will definitely send and receive at 14-bit resolution in the upcoming OS release. Pitch Bend was already 14-bit I think... in the upcoming release the Modulation wheel CC will be 14-bit, as well as Filter Cutoff.
Using the Mod wheel to control filter cutoff, now allows VERY smooth tweaks to be recorded and played back via MIDI. It sounds amazingly better. 8)
PHC
Post by PHC » Mon Jun 11, 2007 9:56 pm
What about the modwheel to control the amount of Vol/Pitch/Filter from external sources? I hope my previous post hasn't gone unnoticed.
denoiser
Post by denoiser » Tue Jun 12, 2007 6:16 pm
When I use S+H or noise as a mod source, if I press a button on the panel the "hold" stands for a longer time. Has anybody else noticed this? It's more evident with the noise.
It could be a hardware related problem or a software problem. I don't have any idea about how these functions are actually implemented. By the way, does anybody know? If it's a software bug a fix would be so nice :)
Sorry if I ask for current "problems" instead of new features but IMHO the LP worths it, like in the ad :P
dlearyus
Next OS For LPTE
Post by dlearyus » Wed Jun 13, 2007 11:35 pm
could you "leak" a release date timeframe so I can get some sleep?
Signed,
Guarding My Matress Tag
Post by Amos » Thu Jun 14, 2007 2:38 pm
still in alpha testing
beta release tomorrow, we hope
actual release a week after beta, barring unforseen changes.
so realistically about a month. ;)
hopefully sooner!
[edit]: Just to clarify, most of the super-fancy features we are discussing will take some real time to implement; we are putting them on our "version 2.0" wish list. There will be a firmware update soon, but it will be v1.03C with a few bugfixes and several new features, but nothing earth-shaking.
Unless of course you have a Voyager and an LP and think it would be earth-shaking to play them together, duophonically... you'll be able to do that. :)
dlearyus
Firmware
Post by dlearyus » Fri Jun 15, 2007 10:40 am
thnx Amos :) man i gotta tell ya...the ability to add stuff to my LPTE totally rox my sox...its like getting new hardware for free :)
BRILLIANT DESIGN!
ps is the new LP Tutorial Video comin out soon? I could REALLY benefit from that i think :)
calyx93
Re: Firmware
Post by calyx93 » Fri Jun 15, 2007 11:54 am
dlearyus wrote:ps is the new LP Tutorial Video comin out soon? I could REALLY benefit from that i think :)
No offense - but is a tutorial really needed for something as easy to use as the LP?
“I have stretched ropes from steeple to steeple; garlands from window to window; golden chains from star to star, and I dance.” - Rimbaud
dlearyus
re:
Post by dlearyus » Fri Jun 15, 2007 1:33 pm
yup calyx believe it or not i am a TOTAL newbie with these things. Amazing little box. I was hoping a basic tutorial might help me get past the presets. twiddling the knobs is lotsa fun fer sure but i know i havent even scratched the surface of this device yet.. :) i can use all the help i can get however minimal ;)
GregAE
Re: re:
Post by GregAE » Sat Jun 16, 2007 9:16 am
dlearyus wrote:yup calyx believe it or not i am a TOTAL newbie with these things. Amazing little box. I was hoping a basic tutorial might help me get past the presets. twiddling the knobs is lotsa fun fer sure but i know i havent even scratched the surface of this device yet.. :) i can use all the help i can get however minimal ;)
I'd suggest you pick up a copy of 'Power Tools for Synthesizer Programming' by Jim Aiken. It explains synthesis in depth (all forms, not just analog), including oscillators, filters, envelopes, LFO's, modulation and effects. The book is pretty comprehensive, and would make a great introduction for a newbie.
You can check it out here:
http://www.amazon.com/Power-Tools-Synth ... 660&sr=8-1
simbadadred
Post by simbadadred » Mon Jun 25, 2007 10:29 am
I would like to have the ability to adjust the LCD Contrast. I feel that it's too bright and that the pixels will probably start dimming after 7-8 years. I'd only have my brightness up to 40%.
Moomin
Post by Moomin » Mon Jun 25, 2007 11:03 am
Is that even possible to add with software updates?
dlearyus
Analogue Function
Post by dlearyus » Mon Jun 25, 2007 6:54 pm
Thnx much GregAE I will def pick up a copy of that. Cheers m8 :))
http://www.amazon.com/Power-Tools-Synth ... 660&sr=8-1[/quote]
