Page 2 of 3
Posted: Sat Jan 09, 2010 10:00 pm
by Cole Gaskins
Dang! I just sold my POG before I got the Voyager!
Posted: Sat Jan 09, 2010 11:21 pm
by MarkM
Another great pedal company that are very inexpensive are the Moen effects. I have the Compressor and it will compete with a Keeley, yet it costs only $65. Very clean sounding.
http://moeneffects.com/
Posted: Sun Jan 10, 2010 10:20 am
by Acid Mitch
EricK wrote:
Electro Harmonix goes really great with Moog, and if you want to take them to the next level they can be modded out too.
Word on the street is that the newer Nano range can't be modded, or at least the old mods don't work.
EricK wrote:
Im about to get the Graphic Fuzz for my sister, and Im going to see how it works in the mixer out filter in and Ill let you know how that goes.
Also, if you are spending upwards ot 200 on a delay, consider the Boss RE20 Space Echo. It has tap tempo and its $250. It also is usable with an expression pedal.
The Boss RE-20 is great. When not being used as a delay I like the reverb on percussion.
Be sure to let us know how you get on with the graphic fuzz. It looks like it could replace a few different overdrive/distortion pedals.
Posted: Tue Jan 12, 2010 11:03 am
by spittingoutteeth
Can anyone recommend a good compressor pedal to use with the Voyager?
I used to use an RE-20 space echo pedal, but I found it to be too muddy and colored the sound way too much. Using a Carbon Copy delay now & am much happier.
Posted: Tue Jan 12, 2010 3:16 pm
by EricK
I think when I do that, Ill post some audio samples, cause I don't think I can really get away with doing any video demos at this time.
Posted: Tue Jan 12, 2010 4:20 pm
by Just Me
The effects I use:
The Foogers in my sig
TC M300
Ibanex DM1000
DOD Flanger 375
BBE Stinger
Late 70's EH Small Clone
Line 6 RotoMachine
70's MXR Distortion +
Memphis Rotosound
EV2710 'Fixed Filter Banks' :p
JBL noise gates
Furman LCX's
Digitech BP8
Leslie combo preamp and 710 Leslie
Posted: Wed Jan 13, 2010 12:18 am
by Klopfgeist
I don't really understand why anyone would want to use a compressor pedal with the voyager. I mean, I understand overloading an LA-2A, but I don't think a Dyna Comp or a Keeley compressor would really do much for the voyager other than bring up unwanted noise. (if you want to have a "clickier" attack, just play with the vca's envelope :D )
Posted: Wed Jan 13, 2010 3:36 am
by MarkM
I don't use the Moen compressor on my Voyager. I was pointing out that Moen makes a lot of great pedals for not much money, and the quality is quite good. I use that compressor for guitar. However, I do have a compressor on my effects rack that I use as a limiter.
Posted: Wed Jan 13, 2010 3:41 am
by ikazlar
I use an Eventide H-8000FW and a TC Electronic M-3000
8)
Posted: Wed Jan 13, 2010 6:48 am
by psicolor
I'm searching for an analog octaver pedal for my voyager. I tried the EBS OctaBass with the Voyager yesterday, but the follower-circuit gets in trouble if i use more than one oscillator.
Any recommodations?
Re: What effects are you using with your Voyager?
Posted: Sat Mar 31, 2012 6:04 pm
by PortableFishy
Does the mixer out/filter in jack send/return line level signals or instrument level signals? I want to use some effects pedals here as well but not sure if I need an attenuator to convert the send from line level to instrument level and then on the return have a DI convert it from instrument level back to line. How do you guys use your effects pedals on this jack?
Is this the right chain that is needed for the effects pedals?
Voyager Mixer Out -> Line to Instrument Level Converter/Attenuator -> Effects Pedal -> DI (Instrument to Line Level) -> Voyager Mixer In
Or do you just plug it in directly?
Voyager Mixer Out -> Effects Pedal -> Voyager Mixer In
Posted: Sun Apr 01, 2012 4:21 pm
by Titus Raindrops
Try the Oto Biscuit! Not only will it make your Voyager cry, it can also be transformed into a synth in its own right with the Der Oto firmware update. For free!
Posted: Mon Apr 02, 2012 6:07 am
by Prime NL
I use a TC Electronics Fireworx for Reverb alike stuff.....and a Strymon Timeline for the Delays.... :)
Posted: Mon Apr 02, 2012 8:52 am
by namahshaman
MF-101, MF-102, MF-108, Roland RE-20, Boss RT-20, Line6 DL4, KP3. (and strongly considering an MXR carbon copy or holding out for an affordable MF-104). If I could only keep one non-fooger pedal, it would be the RE-20... hopefully one day I will replace it with the real thing. :D
Posted: Sat Apr 07, 2012 10:18 am
by bhrama
Eventide - Modfactor/Space/Timefactor
EHX - Big Muff Bass
Lovetone - Doppelganger & Wobulator
