It works fine, except that the attack on the VCA stopped responding. It seems sort of "stuck" on a slow attack (around 2-3 seconds). Which is annoying in the extreme, since it takes out all the punchiness. Everything else works. I took it to one of the only shops in town that said they would work on it, and the guy says he thinks it needs a new IC chip for the attack circuit. Here's the second part of the problem. If he's right, and the IC for attack in the VCA is bad, where do I get that. He's tried the suppliers he uses and tells me the part is listed as obsolete. Well, obviously, it's old equipment. So does anyone know where to get a part like that for a prodigy?
Or does anyone have a suggestion, since the guy at the shop only thinks that is what the problem is. Could the problem be anything else?
Any thoughts or info that will help me get my punchy leads back?
