minitaur editor win7 doesnt work
tommy-
Post by tommy- » Mon May 21, 2012 5:47 pm
hey, i use the minitaur since a week now, and i check the internet all the time for the editorissue but it seems that nobody has the problem i have, and my problem is, nothing works :)
i use windows 7
under ableton everything works fine so far, but the editor just doesnt work.
when i go to settings i see 5 devices but in the first five devices none of my touchable controller is listd and i cant scroll down.
while in ableton and turning knobs in the edtior nothing hapopens too.
any ideas?
muksys
Re: minitaur editor win7 doesnt work
Post by muksys » Tue May 22, 2012 9:35 pm
If I am understanding you correctly, the issue you have is using Ableton & the editor at the same time? You will need to use both USB and MIDI DIN for this to work. Connect the Editor to the Minituar's USB (Moog Minitaur?Moog Mini) for both INPUT & OUTPUT. This way, any change you make on the Minitaur will update on the Editor and Vice Versa. Also how you are able to load patches from Editor and capture patches from Minitaur. In Ableton (I don't use Ableton, but I'm sure it's not much different than Cubase 5), connect your MIDI track to whatever OUT port you have the Minitaur hooked up to.
You cannot use the Editor to connect a controller to the Minitaur. For that you either need a DAW or MIDIOX.
