Any Minimoog owners that also really like the Little Phatty?
Re: Any Minimoog owners that also really like the Little Pha
Oh, well I thought someone said on here awhile back that it couldn't.
This is possible. Pot mapping can be used to assign the desired second parameter to another knob.EricK wrote:I don't like the fact that you can't adjust more than one parameter at a time on a module (for instance, you can't adjust the filter cutoff and resonance simultaneously).
Stage II, MF-102, MF-105m, MF-107, paia theremin, akai s2000, yamaha pss 680, yamaha cp 25, and other stuff
I didn't know the phatty did pot mapping, but it's not the same. Even the Voyager's pot mapping is limited.
I agree. However, I've never used the pot mapping myself. Pushing buttons has become a way of life for me.EricK wrote:I didn't know the phatty did pot mapping, but it's not the same. Even the Voyager's pot mapping is limited.
You should try Pot Mapping sometime - it has a lot to offer. For an introduction to PM on the Voyager, check out the article on KnobTweak:Voltor07 wrote:I agree. However, I've never used the pot mapping myself. Pushing buttons has become a way of life for me.EricK wrote:I didn't know the phatty did pot mapping, but it's not the same. Even the Voyager's pot mapping is limited.
KT > Files > Voyager > Pot Mapping.pdf
The article includes a dozen examples on useful PMs, like controlling Filter Cutoff with the Pitch Bend wheel, and using the MW to adjust the Master Volume -performance enhancers that can really make a difference in your solos!
- Greg
I agree that using Pot Mapping to adjust multiple parameters is not the same as using RAC to do it. Call me paranoid, tell me I have a wild imagination, but I can hear the digital stepping that occurs when I control parameters with MIDI. I don't like it either, so I'm going to stick to dedicated knobs on the Phatty... Well, "dedicated"- you know what I mean.EricK wrote:I didn't know the phatty did pot mapping, but it's not the same. Even the Voyager's pot mapping is limited.
Agreed. Even with 14bit, I can hear a difference when directly controlling the filter and via MIDI. I did make a panel on my iPad for the LP, but that was simply to make it easier to access deep menu items like pole switching, arp, mod source/dest changes, etc.Kenneth wrote:I agree that using Pot Mapping to adjust multiple parameters is not the same as using RAC to do it. Call me paranoid, tell me I have a wild imagination, but I can hear the digital stepping that occurs when I control parameters with MIDI. I don't like it either, so I'm going to stick to dedicated knobs on the Phatty... Well, "dedicated"- you know what I mean.EricK wrote:I didn't know the phatty did pot mapping, but it's not the same. Even the Voyager's pot mapping is limited.
- thealien666
Hahahaha! I doubt that very much!muksys wrote: Agreed. Even with 14bit, I can hear a difference when directly controlling the filter and via MIDI.
You can hear a 1/16384 th step, roughly equivalent to 1.2 Hertz difference in pitch (for cutoff from 0 to 20 KHz) ? I'm an alien and I can't distinguish that with my Spock ears !
Only a precise frequency meter can show them, not without some difficulty (due to drift).
What you must have been hearing instead will probably have been an averaging if those values down to the "regular" 7 bits MIDI CC 256 possible values... Which correspond to 1/255 step or roughly 78 Hertz (for range of 0 to 20,000 KHz) which ARE audible on extreme ranges (like cutoff from 0 to 20 KHz).
An external midi controller really opens up the phatty. I pretty much always use the panel knob for filter cutoff. I do get zippering using the BCF2000 even when using 14-bit due to the scan rate on the faders.
I have been eyeing up a Bitstream.
http://www.waveidea.com/en/products/bit ... /index.php
- thealien666
Yes, that's another very important factor in the equation. If zippering artifacts are audible even when using 14 NRPN MIDI messages, that's indeed due to poorly designed (read that too slow) scanning rate and conversion time of the panel potentiometers.Sir Nose wrote:I do get zippering using the BCF2000 even when using 14-bit due to the scan rate on the faders.
Anybody using a kurzweil pc3 as a "controlling surface" for the slim phatty?
I will have to do that in the next few days, and it would be nice to get some advice from somebidy who already experienced glitches and devised shortcuts.
Ok, thank you Spock for overabundently correcting me. Yes, It may be possible im using 7 bit when i think I'm using 14 bit But. If its my understanding that all controls on the LP that are not RAC are 14bit. I most certainly can hear stepping when I grab the cutoff and turn it very quickly just before RAC kicks in.thealien666 wrote:Hahahaha! I doubt that very much!muksys wrote: Agreed. Even with 14bit, I can hear a difference when directly controlling the filter and via MIDI.
You can hear a 1/16384 th step, roughly equivalent to 1.2 Hertz difference in pitch (for cutoff from 0 to 20 KHz) ? I'm an alien and I can't distinguish that with my Spock ears !![]()
Please, next time, keep the ego down to a low roar. I don't visit the forums much lately. The nasty fanboyisms are out of control. The ideals of Moog are getting lost here.
Peeez!
I believe that .muksys wrote: I can hear a difference when directly controlling the filter and via MIDI.
[btw: +1 re "fanboyism". Peace! Everybody here is passionate and competent, and a moog user. I don't see any major synth designer here, who is entitled to superiority].
Not in the strict technical sense.
But I believe that using an external controller you feel something wrong "between your hands and your ears".
Even at 14 bit, the sum of digital/analogue passages and different hardware CAN make the sound adjustments feel detectable.
You won't necessarily HEAR them, but you will FEEL them.
I can't ear 1.2 hertz differences, but my fingertips can definitely detect time delays and curve distortions (it happens all the time with several synths. Heck: don't you sometime "feel " that a total-analogue pot is on the verge of needing maintenance? That it doesn "sound" right? After long time spent on synths, I have that kind of "bad tactile feeling"].
This is why I love hardware so much, and avoid long control chains whenever is possible (which is: seldom.
EG: Is there a way of deactivating the phatty's leds? I am disturbed by the "optical quantization" they force on me.
What's the point of having nice, hi-resolution pots which detect variations in 1/5000 steps, when you have 16-step [or whatever] flashing lights distracting you?
I'd rather rely on my ears only. They damn sure detect changes in finer than 1/16th steps.
There's nothing strictly AUDIBLE there, there's no stepping, but there indeed is a SENSORIAL limitation in the hand/eye/ear operation.
So, 14 bit resolution has stricly nothing to do with it.
