Voyager tuning
Voyager tuning
Hello everybody.
Aquired my Voyager Fire Red in september last year, and have been programming it for my different live setups since then. However, I´m having an issue understanding the tuning of it. I tuned it (following the tuning instructions found on the web) and the default patch (used when tuning) is in tune and everything works perfectly. But when I started working on it again this week, some of the patches are completely out of tune, and some are in perfect tune.. OSC 2 and 3 are set to pitch 0 but OSC 1 (on some of my presets) are almost half note too low. But again, some presets are not..
Questions:
- is the main tuning pot saved to the preset? As I understand it´s not, but maybe ´m wrong.
- is there any logical explanation of this tuning issue? Would it fix stuff if I tuned the synth again? Last time was in mid january.
- do I need to tune it, and then make new presets to save over the old ones?
Øystein Moen, Norway
Questions:
- Bending_Bus
Re: Voyager tuning
Your not the only one who has noticed this, don't have any explanation. After opening up the back and tuning some presents are spot on and others osc1 is slightly sharp/flat. There doesn't seem to be any pitch modulation or anything to explain why it is doing it. The fine tune knob setting isn't being saved, I don't think? End up having to retune using fine tune each time presets are switched. Not a half step here, a matter of cents.
- thealien666
Re: Voyager tuning
You are aware, of course, that the Voyager needs at least 20-30 minutes to be completely warmed-up before playing or calibrating it ?
And you are also aware that when performing the tuning procedure with the back of the instrument open, the internal temperature won't be the same as when it is closed, and will influence its tuning somewhat ?
And that's also one of the reasons why there are holes in the casing for trimpot access on a Minimoog D, not only for convenience.
But in the case of the Voyager, the design of the analog board does not permit access to the trimpots from the outside without opening the back, unfortunately.
But it could also be a small bug on the digital side of things, causing this variation.
Another member here, Omaroo, recently had to perform a Factory Sounds reset because all of them were offset by 1 semitone flat, compared to the panel mode.
- Bending_Bus
Re: Voyager tuning
Aware of warm up time and pitch going slightly sharp once closing the case...it's not that.
It's that an osc1 "C" on one preset is different than an osc1 "C" on a different preset, for no apparent reason. I'm using a Peterson analog strobe which is darn accurate. You would think you could put the instrument in tune using the fine tune knob at the beginning of the session, and then switch thru preset sounds live and have it all be good. But it ain't all good, each preset is recalling sharp/flat in relation to initial parameters. It just seems really currious...how it can be storing that.
Not sure if that is the problem the original poster is seeing but sounds similar.
Re: Voyager tuning
i once had problems after upgrading the os.
when again upgraded the last /newest version, all problems disappeared.
btw i also use a peterson which is much more occurate then a analogue synth can ever be, although big chances as you describe are not common
Re: Voyager tuning
The problem is the same for me, the OSC1 has a different tuning on two individual presets.
So what really seem to be a fix? I´ll try to upgrade to the latest os, and see how it performs.
- RL
Re: Voyager tuning
Make sure the pot mapping does not affect osc1!Bending_Bus wrote:It's that an osc1 "C" on one preset is different than an osc1 "C" on a different preset, for no apparent reason.
http://www.moogmusic.de
Re: Voyager tuning
RL wrote:Make sure the pot mapping does not affect osc1!Bending_Bus wrote:It's that an osc1 "C" on one preset is different than an osc1 "C" on a different preset, for no apparent reason.
What does that mean, is this a setting in the menu?
Re: Voyager tuning
Pot Mapping is located in the EDIT menu, 5.4.oysteinmoen wrote:RL wrote:Make sure the pot mapping does not affect osc1!Bending_Bus wrote:It's that an osc1 "C" on one preset is different than an osc1 "C" on a different preset, for no apparent reason.
For info on Pot Mapping, check out the article on KnobTweak:
KnobTweak > Files > Voyager > Pot Mapping.pdf
- Greg
Re: Voyager tuning
Thanks. Just signed up for it. Will try to upgrade OS first of all, and come back with info later.
Re: Voyager tuning
Ok, upgraded the OS, no problem, but this had nothing to do with it.
The POTMAPPING were the bad guy, and all I had to do was to set all 4 MAPS to 0% and VOILA! Every preset is in tune.
Re: Voyager tuning
what potmapping ? in the defaultpatch ?
Re: Voyager tuning
Good thread. I think, that before I factory reset, that this might have been my one semitone flat problem too. For a reset to fix my issue means that it had to be a setting... obviously. Ah, we get to know our machines better by the day eh?
Sub 37 Tribute, Waldorf Blofeld, MF-104M SD, Axiom 25, UMX-610, Propellerhead Balance, Truth B1030A mons, MacBook Pro i7, Live 9, Logic 10, Animoog.
Re: Voyager tuning
yes, it's a wonderful machine too.
- RL
Re: Voyager tuning
BTW you can reset all pot mapping settings of a whole bank in the hidden factory menu:
MASTER/Copyright Info, ENTER, +1 --> Pot Mapping
Have fun,
Rudi
Have fun,
Rudi
