Sending midi to ableton from moog
I can't figure out why my midi notes aren't being received by ableton? I can write notes in ableton that will play the moog but...
Also, I notice that every time I restart the phatty the Midi Setup menu changes to "all notes off". Does this mean that that is what it is set as? Changing the setting to send all cc's doesn't do anything :/
Re: Sending midi to ableton from moog
Allssoo, ableton is receiving midi when i turn nobs on the phatty...
- xombiexplox
Don't take this as me talking down to you or anything but...
...I can't tell you how many times I've connected and reconnected MIDI cables today wondering why there was no sound only to realize I didn't have it plugged into the MIDI IN when I was controlling it from Ableton, or not having it plugged into the MIDI OUT when I was using the LP to control my Slim.
GEAR: Slingshot, yo-yo, baseball cap, heaphones, gummi wormz
- xombiexplox
Go into MIDI preferences and set it up there!zac darmon wrote:Allssoo, ableton is receiving midi when i turn nobs on the phatty...
:3
everything is set up right in ableton... all the midi cables are set up right. Everything is working other than ableton receiving notes from the keyboard.
I don't know what's going on... I've tried restarting everything with only the usb plugged in... ugh
You have to create an audio track. "Ext In" should reflect your port, which would be 1 or 2 whichever you have it plugged into your interface. Then arm the track. Play it. If you hear it, move to next step. Plug the Slim Phatty into your computer via USB. Then go to Live preferences menu and choose the midi sync menu. Under midi ports you will see the Slim Phatty. Arm the track section in and out. After you do this, move to step 3. Create a midi track. Where it says Midi To, - you have to choose the Slim Phatty. Next, create a midi clip, and punch in some midi notes. It should work fine
Thanks, I have everything set up right though... I think something is wrong with my ableton or something because when I directly record midi from my keyboard using the midi to usb adapter it is oddly extreeeeeeemely slow now. Unable to play anything because after playing two or three notes then I'll start to hear the notes...vertibration wrote:You have to create an audio track. "Ext In" should reflect your port, which would be 1 or 2 whichever you have it plugged into your interface. Then arm the track. Play it. If you hear it, move to next step. Plug the Slim Phatty into your computer via USB. Then go to Live preferences menu and choose the midi sync menu. Under midi ports you will see the Slim Phatty. Arm the track section in and out. After you do this, move to step 3. Create a midi track. Where it says Midi To, - you have to choose the Slim Phatty. Next, create a midi clip, and punch in some midi notes. It should work fine
Ok so I opened up a new project and the terrible latency had to do with something in the project, but still no moog being noticed. I'm wondering why my moog every time I restart it the midi setup menu goes to "all note off" ...? is that normal?
This is definitely a problem with the moog because when i go to midi setup in the mac osx preferences the notes played on the keyboard aren't being recognized. I've rebooted everything, restored factory settings, cycled and what not without midi cables in, un plugged and plugged bad in to different socket... what haven't I done?
- xombiexplox
I don't want to sound mean but have you read the manual?zac darmon wrote:This is definitely a problem with the moog because when i go to midi setup in the mac osx preferences the notes played on the keyboard aren't being recognized. I've rebooted everything, restored factory settings, cycled and what not without midi cables in, un plugged and plugged bad in to different socket... what haven't I done?
I believe the MIDI All Notes Off is just a command you have to actually 'SELECT' and click and it turns off all MIDI notes to prevent hanging notes. I am pretty sure it says this in the manual.
- xombiexplox
Also, tell us exactly what your connections are, and what settings you're using in Ableton. A screenshot could be helpful too!zac darmon wrote:This is definitely a problem with the moog because when i go to midi setup in the mac osx preferences the notes played on the keyboard aren't being recognized. I've rebooted everything, restored factory settings, cycled and what not without midi cables in, un plugged and plugged bad in to different socket... what haven't I done?
it's not ableton. I can see if my connections are working from the Mac os x audio midi set up in the preferences
- xombiexplox
Okay cool. You've said that repeatedly though, could you post how you've got your equipment set up now? Unless you've already figured out how to get it working. Pictures are helpful too.zac darmon wrote:it's not ableton. I can see if my connections are working from the Mac os x audio midi set up in the preferences
I have the same exact setup as you, my SP and my LP are being run into my Mac into Ableton and it's working fine. In the IT world this would probably be described as a PEBKAC situation and not a Moog situation ;]
Just teasing
yeah i know it's most definitely me doing something wrong. So... Midi in and out cables are connected from the moots midi in and the midi out to the keyboard mini in and out... I also don't have any settings on the slim to merge midi data. I didn't think that was needed but I got an e-mail from a guy at moog saying this: "When you turn the knobs, the MIDI CC information is being seen and recorded by Ableton just fine. This suggests that the MIDI output of the Slim is working just fine. It will not send note on/off messages if the notes are being sent to it viz MIDI. If it was set up on the same track that would start a MIDI feedback loop. The only way the Slim will send notes out would be through the MIDI THRU port or if you merged MIDI Out with MIDI IN to send notes. This would however defeat the purpose of controlling it from a computer."
OMG... i kind of got it working lmao but it's doing what he said it would do which is do a midi loop thing.
ok I got it working... FML. for some reason I didn't think any midi merge was needed. Sorry everybody! lol Basically I just had to have under "MIDI MERGE - DIN IN: BOTH OUT"
p.s. I did actually try all the midi merge settings at one point but in order for it to work i had to do a recycle
btw if anyone wants to hear my music I've made so far without being able to use the keyboard lol http://www.soundcloud.com/officialcymatik
all the sounds are made with the moog. probably pretty obvious.
I am so god dam happy right now that it's finally working. And I'm glad it was just me being stupid ;P
