OLFAudio
Post
by OLFAudio » Wed Jun 01, 2005 2:17 pm
Ah Ha-
Got it to work by dusting off my old roland midi controller (pc 300)with dead keys. I hooked it up via usb and ran the only midi out port to the voyager. Had no idea I could use that midi out for to transmit sys ex through the controller.
Thanks everybody for the advice
Once again, Must avoid digidesign interfaces for anything other than Protools
Lengai
Post
by Lengai » Thu Jun 02, 2005 3:06 am
ezratrice,
Thanks for the tip. I will try the same thing with my Oxygen 8. It has USB so hopefully it will work.
OLFAudio
Post
by OLFAudio » Thu Jun 02, 2005 10:16 am
Lengal-
There was a switch on my PC-300 (controller) that let me choose between 'keyboard' and 'pc'. It did not work in 'keyboard' mode but it did in 'pc' mode. You may need to look into tht as well.
Good luck.
