Hi everybody.
I am trying to use my Axiom-61 with the Animoog on iPad, via a UNO MIDI Interface.
Many things are working fine: notes, pitch-bend, mod...
But the notes play as if you press ONLY the lower end of a Animoog virtual key.
Is there a MIDI CC covering the modulation obtained swiping your finger on a Animoog virtual key?
I tried many of them (standard and not standard): 1, 2, 11, 16, 18, 131, 144, ...
Thanks a lot in advance for any help!!!
Nick
Animoog MIDI question
Re: Animoog MIDI question
not sure if I understood your question, but...
in ENV/MOD tab, find the mod that has 'poly-pressure' under CONTROL, and change that to 'velocity'. That way you change he modulation obtained by swiping your finger on a virtual key with the velocity on the MIDI keyboard.
hope that helps!
hope that helps!
