MOOG+OTHER SINTH QUESTIONS
Everything Phatty.
will o wisp
Post by will o wisp » Sat Aug 06, 2011 6:35 am
Fellow moog users i hope you are doing great
i have two questions im about to get or a dark energy or an evolver from dave smith to join to my moog is possible or only with the dark energy?
with another dark energy i would have 1 more osc? 1 more lfo? syncable?
with the evolver you think i can use its features on the moog? like the extra lfo and extra osc?
thanks a lot and best wishes my moog friends
praxisaxis
Re: MOOG+OTHER SINTH QUESTIONS
Post by praxisaxis » Sun Aug 07, 2011 12:42 am
I don't know much about the Dark Energy... but there's many ways you can use the synths in conjunction. The LP has only got CV in, so you could use CV to control it in various ways, but I'm not sure what the DA offers.
They are both MIDI however, and this opens up a large number of possibilities. The first thing I'd be trying is simply to send MIDI out to the DA, from the LP, and see how fat I can get a mono sound :) :), probably doubling the octave. I know it'll sound sweet without even trying it :) .
The LP has external audio in, which passes through its filter section. That'd be worth fiddling with. The DA also has external audio in too.
The fact is there's tonnes of different ways you could get these two beasts working in conjunction. The only thing I'm not sure you could do is to have duo-phonic; although the LP allows this feature I'm not sure you can assign the DA in that way.
The best thing to do is listen closely to both synths, work out specifically how they sound different, then use these differences to allow them to compliment each other.
will o wisp
Post by will o wisp » Sun Aug 07, 2011 2:25 pm
ok thanks for the answer the only thing i still need to know if i can use the lfo of dark energy as second lfo
thanks
will o wisp
Post by will o wisp » Tue Aug 16, 2011 12:33 pm
sorry for keep bothering with these but next week i have to buy dark energy before going back to my country and i only want to buy if these will giveme
1 EXTRA OSC ( that i alredy know will give me) i wouls be able to use the fm of DE?
1 EXTRA LFO wich destinations i will be able to have
thanks a lot hope someone test these alredy
Kenneth
Post by Kenneth » Tue Aug 16, 2011 2:17 pm
I assume you'd be able to use the dark energy lfo in conjunction with the Moog lfo no problem. the oscillator question is something that really depends on how you want to use it. you'd be able to play Moog and dark energy oscillators with one keyboard, but Im sure you'd have to tweak the parameters separately. I hope this helps.
EMwhite
Post by EMwhite » Tue Aug 16, 2011 6:39 pm
On other scenario is to play the Dark Energy with no Filter engaged (via Phatty Kbd over Midi) and take the raw OSC out with open DE envelopes into the Phatty Audio in to be processed by the Phatty Filter and envelopes.
As for LFO, certain the Phatty is compatible but keep in mind that most LFOs that push sine/tri wave run from -2.5V to +2.5V (such as the CP-251). The DE has the same specifications; you would merely need to take the 1/8th" cable to 1/4" cable and put it into any of the 3 CVs (Vol, Pitch, Filter) on the Phatty.
You WON'T be able to apply the external DE based LFO into LPs wave (for example) but certainly you can use your internal LFO for this and then use the external for the bits above.
Hope this added information helps. As disclaimer, I haven't tried any of this with the Doepfer gear but the specifications clearly show compatible voltages. Dark Energy, Phatty/Voyager/Taurus, and Oberheim SEMs all play pretty well together these days.
GregAE
Post by GregAE » Tue Aug 16, 2011 8:26 pm
Hi Will o',
To answer your questions, the DE will provide you with an extra oscillator that you can use to expand the Phatty, either as a CV to provide modulations (FM, timbre, or amplitude), or as an extra oscillator (this also works well with the Voyager, too). Note that you can't access DE's oscillator raw output, as it must pass through the DE's filter before going to the VCA, but you can always open the filter all the way (to minimize the effect on the oscillator) and adjust the VCA output so that it passes signal all the time.
As for the LFO, the DE has a separate CV output for LFO1, as well as an envelope CV output (you can't have too many of either, IMHO!). Both of these CV outputs are on 3.5mm jacks, but the conversion to 1/4" isn't much of a problem with a few adapters.
Add to that: you can control the DE from MIDI or from a control voltage, which makes for a very versatile little module. You can also use the DE as a MIDI-to-CV converter - handy!
In short, go for the Dark Energy - you won't be disappointed!
- Greg
will o wisp
Post by will o wisp » Sun Aug 21, 2011 5:58 pm
Thanks a lot guys i apreciate a lot the help im new in these semi modular world heheheh
i m in europe now and wanted to take or evolver desktop or dark energy but if i can mix my moog together with DE will be a big expansion to my beloved SP
i apity you cant do the same with evolver
what would be nice and a killer combo would be
do the SP+DE combo and send to evolver Inputs to have High pass, Digital distortion, Feedback And Delay =)
so you will have a huge 3 osc 2 lfo sinth with some killer digital fx i think ill go first with DE and when i get the extra i get evolver
THANKS AGAIN FOR THE FEEFBACK I GET BACK TO YOU WITH SOME SAMPLES WHEN IM BACK IN STUDIO
EMwhite
Post by EMwhite » Sun Aug 21, 2011 6:29 pm
Depends what you are after.
Dark Energy is all analog with the exception of the somewhat limited Midi section (e.g. LFOs are not Midi Sync-able) but offers plenty of patching opportunity.
Evolver has zero patching, is Midi only but has 2 digital OSCs + effects + Step sequencer, hidden behind a somewhat convoluted interface.
If you are a tweaker that just wants to twiddle knobs and experiment primarily with Control Voltages, then DE is for you. If you want all the bells and whistles and have time to delve into dozens if not hundreds of settings/parameters, then the Evolver can be alot of fun.
Doepfer has a knack in making something (even something digitally controlled such as the Dark Time) feel like pure analog; certainly, Dark Energy is pure Analog (about as analog as the Midi SEM, in that there is merely a Midi to CV converter onboard). Dave Smith doesn't care about any of that, he's into packing as much functionality behind a three digit seven segment display as he can.
Here's a really really really really good YouTube video that give a quick run through of the Evolver (no talking, just on screen narrative): http://www.youtube.com/watch?v=sV93_FB3XSI
Here's Nick Batt's overview of the Dark Energy, also very good: http://www.sonicstate.com/news/2009/07/ ... nthesizer/ (Nick always does an excellent job)
Assar
Post by Assar » Sun Mar 18, 2012 2:54 pm
I got myself a Dark Energy this friday.
Today Doepfer announced it is discontinued, only stock sale left.
http://www.doepfer.de/Dark_Energy_e.htm
On the right side of the rope for a change ...
:D
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
unfiltered37
Post by unfiltered37 » Sun Mar 18, 2012 3:38 pm
For pure sound, the DE blows the evolver out of the water. It is more of a tweaker synth, though, less so than a keyboard synth. Doepfer is one of the few modern companies that make not necessarily vintage sounding, but very raw and gritty synths.
Omaroo
Post by Omaroo » Sun Mar 18, 2012 3:59 pm
Dark Energy is discontinued.
Long live Dark Energy II
http://www.doepfer.de/Dark_Energy_II_e.htm
Sub 37 Tribute, Waldorf Blofeld, MF-104M SD, Axiom 25, UMX-610, Propellerhead Balance, Truth B1030A mons, MacBook Pro i7, Live 9, Logic 10, Animoog.
Assar
Post by Assar » Sun Mar 18, 2012 4:07 pm
Omaroo wrote:Long live Dark Energy II
If it is good, I maybe get one of those too.
But only -12dB filter???
Sir Nose
Post by Sir Nose » Sun Mar 18, 2012 4:15 pm
Continuously variable filter mode like the SEM though. Some other major difference from the Dark Energy I as well.
