LP Stage II KB tracking problem
Everything Phatty.
bealtown
Post by bealtown » Mon Jun 06, 2011 12:38 am
This just occurred yesterday: The keys only track every other key depressed, unless each note is played detached (without any legato). Thus if I play a scale CDEFG only CEG play. IF I play CEG, only C & G play. What has happened to my moog, and can this be easily fixed?
When is the new OS coming out anyhow?
John
Sir Nose
Re: LP Stage II KB tracking problem
Post by Sir Nose » Mon Jun 06, 2011 8:01 am
Check your note priorety setting. Set it to last. If it is not that, ... I would contact moog support directly by phone or email.
New os should be out soon. A beta version is available in another thread.
Post by Amos » Mon Jun 06, 2011 10:48 am
also make sure no MIDI loops (set local on and disconnect any MIDI/USB from the LP, then test again).
if all else fails, try a factory restore (master menu, restore factory). Be sure to back up your presets before doing a factory restore if you have any custom sounds you don't want to lose.
I had promised a new OS update on Friday but I've been working on it 24/7 all weekend... definitely coming today.
