MF 108M? flux
Re: MF 108M? flux
give us your sources! now!
i don't know what that is, but those lfo waveforms look fun...
*edit: it's called the moog cluster flux. and i want it.
Re: MF 108M? flux
http://socialmedia.trademarkia.com/clus ... 74167.html
Bing bang bongo, this is exciting news! First dual stomp Mooger? MF-108M - Midi? Yesola
Some kind of sequencer- related device perhaps?
- latigid on
Re: MF 108M? flux
- latigid on
Re: MF 108M? flux
My guess:
MIDI-sync'able voltage controlled flanger. The other end of the rate knob goes to divisions of the current clock or tap tempo.
Re: MF 108M? flux
A Moog-flavored flange effect would be awesome!latigid on wrote:My guess:
Flanging does great things with sound effects and synth leads, IMO.
Using an old Roland SBF- 325 Stereo Flanger on my Voyager. Good sounding flanger, with CV control of the LFO modulation, but it's having scratchy mood swings- in dire need of service. A Moogerfooger replacement would be most welcome
Anyone else here want to make prediction? Maybe even rumors to share?
Cluster Flux, that could mean anything, man...
Re: MF 108M? flux
So what do you make of the term Cluster?
Perhaps there is more than one thing to choose from?
Multimode FIlter?
What would you hook an LFO to?
Multimode FIlter?
Re: MF 108M? flux
Maybe multiple signal paths with seperate triggers. Overlapping *sequences* if you will of the effected signal.
Re: MF 108M? flux
Cluster means a gathering of stuff, like the cluster of galaxies or a cluster of dust-mites, etc.. Right?
Flux translates to change, flow... So, multiple signal paths, multi-mode processing, the "Flux" beeing the LFO and MIDI. Just musing here, exquezze me please.
Re: MF 108M? flux
What kind of control name ends in 'UNT' ?
Just sayin ...
I've stopped talking now.
- latigid on
Re: MF 108M? flux
AMOunt?
Re: MF 108M? flux
Duh, of course it would be. I was thinking of 'count' which doesn't make sense on a pot. Amount is so obvious. Sorry 'bout that! The teaser pic is intriguing! Also, these ideas on what a Cluster Flux might be is free research for Moog. No need to actually design anything, just let us guess what it is and we'll give Moog all the ideas they need
Re: MF 108M? flux
I'm thinking its a multi lfo fooger with midi and tap tempo. Probably with the ability to combine the different lfos almost like a ring modulator (ie; lfo 1 output, lfo 2 output, sum output, difference output, etc.)
A flanger would be pretty sweet too
Re: MF 108M? flux
Praying for a flanged with LFO waveform selection...
Already making space on my live board...
Shep on Bass - My website & blog
Bitnormal Records - Netlabel specialising in electronica
KADE - Improvised live electronica
Patient Zero - International hip-hop & electronica collaboration
Re: MF 108M? flux
Why is the Bypass on the far right hand side?
Aaron Mulqueen: Moog Subsequent 37 - MF 104M
