So glide is ok!
question: now there is the 14bit midi also on little phatty....is better to set 14bit midi on when little phatty works with slim phatty via midi?
Yes, it's definitely better! If you send 14-bit MIDI from Little Phatty to Slim, it should give very smooth results, almost as good as turning the knobs on the Slim directly.spin wrote:question: now there is the 14bit midi also on little phatty....is better to set 14bit midi on when little phatty works with slim phatty via midi?
ok! sounds good!Amos wrote:Yes, it's definitely better! If you send 14-bit MIDI from Little Phatty to Slim, it should give very smooth results, almost as good as turning the knobs on the Slim directly.spin wrote:question: now there is the 14bit midi also on little phatty....is better to set 14bit midi on when little phatty works with slim phatty via midi?
I forgot about this! OK, here is what's going on:Fuseball wrote:Been playing with the MIDI Sync on the LFO and one thing I noticed is that every time I save a patch it resets the LFO Sync clock value to WH. Is this what it is supposed to do?
As you have LFO Clock division editable from the cursor and Value knob then I personally think it should be updating the LFO Rate as appropriate. At the moment it is two methods to achieve exactly the same thing but only one of them saves with the preset, which certainly caught me out!Amos wrote:I could make it so that the LFO Rate is updated when you change LFO Clock division (only when LFO Sync = MIDI)... but I'm not sure this would be really less confusing than the current scheme. Maybe it would only be differently confusing. What do you think?
That's a pretty valid argument too, although the LFO is more closely tied to the Modulation knob than the arpeggiator is in my mind.spin wrote:but when LFO RATE = midi clock, the rate isn't set by incoming external midi clock? So, like arpeggiator, the rate knob should be disabled when lfo rate = midi clock?
I think it's basically solid/stable at this point.. I will do one more update to tidy up a couple of things, then official release is next week.patobrujo wrote:Hey guys, i've been following this topic closely since i'm pretty exited about all the great features of the new OS. I got one question tho: Is there gonna be an official realease of the new firmware? i don't wanna be a beta tester because i'm playing live regularly with the LP and don't wanna have any troubles with it.... thanks for any info, and Amos thanks for all the great work!!
I don't think it makes sense and it may not be possible to have "legato" envelopes across multiple voices of a poly synth.geoscience wrote:Amos,
Any ideas on the accent thing Joe Moog and I were talking about in polyphonic mode? What are your thoughts on this?
-Geoscience
