Do I need a special cable for CV?
Share your theremin experience: tips, tricks, techniques, favorite theremin moments.
insomniyack
Post by insomniyack » Wed Sep 22, 2010 8:16 pm
Just ordered a Etherwave Plus and I want to use it with my Minimoog Voyager to open up the realm of textures my synth can make but I don't have any 1/4" CV cables.
Do I need a certain 1/4" cable to use for CV or any audio cable will work? Does it make a difference if it's balanced or unbalanced?
Re: Do I need a special cable for CV?
Post by EricK » Thu Sep 23, 2010 12:42 am
An audio cable will do the job. TRS cables are preferred. Im not quite sure what you mean by balanced/unbalanced because im no engineer.
TRS cables are preferred because a mono cable will short to ground on the Foogers, leaving the other CV jacks useless essentially. This is why I can't use my ep1 and another cv because most of my cables are mono.
I don't know if this property is similar on the Voyager so I can't say for sure.
For one cv at a time it should be no problem, in fact, I controlled the volume and pitch cv with my EW+ and my everyday cables and it worked fine.
I have youtube videos demonstrating THe Voyager theremin combo but they aren't that musical
http://www.youtube.com/watch?v=eleittomrtE
kimbo
Post by kimbo » Tue Nov 30, 2010 9:55 am
Balanced and non-balanced, refers to the output (level) of the device, and in the case of a Theremin, this isn't applicable.
As long as you use a good 'audio quality' patch lead with 1/4" jacks, it will be fine. :D
Kimbo:
MacBook Pro, Minimoog Voyager Old School, VX-351, Etherwave Theremin, DSI Prophet 08, Trax Rota-Synth RS-1.
sunny pedaal
Post by sunny pedaal » Thu Dec 02, 2010 5:22 am
and with cv signal it's often a good idea to keep the cable as short as possible espec if you want to control pitch with it. otherwise the tracking might get disturbed/ influenced.
haven't tried it out with the theremin yet, but with other analogsignalsynth's this was recommendable
ydang
Post by ydang » Tue Feb 17, 2015 10:28 am
So which one is the correct one?
ydang
Post by ydang » Wed Feb 18, 2015 3:44 am
IS IT THIS ONE:
ydang
Post by ydang » Wed Feb 18, 2015 3:49 am
