Slim Phatty & Logic
Everything Phatty.
HiFreak1c
Slim Phatty & Logic
Post by HiFreak1c » Sat Nov 27, 2010 1:03 pm
Hey I'm new here so first like to say HI :mrgreen:
I'm thinking about buying a Slim Phatty soon and was wondering about some information.
I'm using Logic 9 along with an Apogee Duet soundcard. I was wondering how the Slim Phatty hooks up?? can it use the USB to
hook it upto the comp??
Also how do I use it with my M-Audio Oxygen 49??
Hope someone can help.
cheers :)
Outbreak Digital / Digital Cohesion / Soundcloud: http://www.soundcloud.com/hi-freak1c
Assar
Re: Slim Phatty & Logic
Post by Assar » Sat Nov 27, 2010 2:03 pm
I don't know specifically about Apogee Duet and Logic (I use RME FF800 and Cubase), but generally you use the Midi/USB interface to send midi data from Logic/computer to the SP, and an audio input in the sound card for the incoming audio signal.
Your M-Audio Oxygen 49 connects either directly to the SP, if you want to controll it manually.
Or you connect it to the computer and route the incoming midi signal from the keyboard out to the SP through Logic. That way you can record the midi signal, play manually or use recorded midi from Logic - whatever you want.
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
anoteoftruth
Post by anoteoftruth » Sat Nov 27, 2010 3:17 pm
You would hook a 1/4 inch line out cable to the breakout cable in apogee duet for audio out.
You cannot get Audio over USB.
Everything works great in logic.
You use the USB to send and receive midi data with your DAW. So you can sequence something in your DAW and control the LP with it... or play the LP and record the midi notes with your DAW.
Hope that helps.
Moog Voyager RME / Moog LP SE 2 / Nord Rack 1 / Microkorg / Korg ER-1 / Triggerfinger / Rocktron Banshee talk box / Ableton live / Guru / Lots of non-electric musical instruments.
HiFreak1c
Post by HiFreak1c » Sat Nov 27, 2010 3:45 pm
ah amazing thanks so much for your reply, ah wicked so means I will not need to get shoot of my Duet that's great news then. Happy to hear it works great with Logic. Does it come with a GUI so you can control the hardware abit like what Virus TI does or is it all hardware base and then you control it over MIDI CC??
anoteoftruth
Post by anoteoftruth » Sun Nov 28, 2010 2:41 pm
It does'nt come with a GUI, but there is a VST editor that you can buy from Moog.
It basically works the same as what you were saying, it's a VST gui that loads up in your DAW and you can edit it and program it from your computer instead of the hardware itself... You can also save and load patches etc.
