I'm thinking of buying a Slim Phatty (I can't afford a Little Phatty
BTW I'm new on these forums.
Actually, I can.narrowcaster wrote:Whichever kind of controller you get, be sure that it has a modwheel that can lock into a set value when you aren't touching it. Unless the Slim Phatty is different from the Little Phatty, there's no way to set a fixed/baseline amount of modulation without parking the mod wheel in a particular position, which is one reason the LP mod wheel isn't spring loaded. Or can someone report that there's a feature on the Slim Phatty that gets around this somehow?
I've had an LP for ages and didn't know this, thanks for droppin' le knowledge bomb on us. This is incredibly useful info since so many controllers don't use the traditional mod/pitch format.GregAE wrote:Actually, I can.narrowcaster wrote:Whichever kind of controller you get, be sure that it has a modwheel that can lock into a set value when you aren't touching it. Unless the Slim Phatty is different from the Little Phatty, there's no way to set a fixed/baseline amount of modulation without parking the mod wheel in a particular position, which is one reason the LP mod wheel isn't spring loaded. Or can someone report that there's a feature on the Slim Phatty that gets around this somehow?
The SP has a new feature that allows you to use the Modulation knob to adjust the modulation amount that is normally controlled by the Modulation wheel. The feature is described on page 18 of the User Manual:
"When the AMOUNT switch is selected, the analog edit control is used to adjust the maximum amount of modulation controlled by the Modulation Wheel. Pressing and holding the AMOUNT switch enables the MODULATION control knob to act as a MOD WHEEL controller. When the MOD WHEEL function is enabled, the AMOUNT switch will blink on and off. To escape this function, press and hold the AMOUNT switch until the light stops blinking."
The cool thing is that this is a global function that affects all presets until you turn it off, so if you want the modulation ON for a bunch of different presets, you can just set it and forget it. This feature gets over-ridden when an external MIDI Mod Wheel command is received, so it can be easily controlled. It also makes it possible to independently set modulation amounts on the fly in multiple LP/SP setups (attention poly-users!).
A pretty neat little feature...
- G
