Hi, I recently bought a Rogue, and have had an ARP Axxe for some time. I am having some difficulty getting satisfying sounds from the Rogue, at least in comparison to the ARP, which can produce (seemingly) many more sounds and has a much deeper growl to it, at least as far as I have gotten (hate the sliders, though).
Would anyone like to share their killer Rogue or Taurus II settings with me?
Also, The Rogue has a constant oscillation sweep that I cannot dial out; is this intrinsic to the design, or do I need an adjustment? When holding a note, it might begin full, but sweeps out so thin you can barely hear it, then back to full again. Also, this is not relative to the keyboard strike, in other words it does not "reset" and begin at full when each key is struck... it kind of behaves like a glide issue but is not controllable by the glide.
Finally, do I have to have my Rogue modded to accept the five-pin connector to use it with a Taurus II controller, or can I do so using the CV or trigger jacks? Thanks!
Rogue users; some suggested settings?
