I tried different things in order to achieve this (Midi to CV, Gate signal, etc.) but the thing that turn out to be the most useful was setting a channel as expression and fixing the 3 values (toe, heel and initial), at the same and connect that channel to the LP's PITCH CV IN. I changed the unit display to volts (as i was thinking: 1 volt per octave), but to my surprise the LP didn't respond to that correlation, in fact to change the pitch in 2 octaves i needed to set the channel value in 2.32 volts and in some sounds in 2.34 volts.
So, ¿anyone can think of a different way to do this? ¿it is normal that the LP didn't respond to the 1 volt per octave realation?
cheers
