Voyager Duophonics!
Voyager Duophonics!
THe best Moog Polyphony Ive seen yet...
Voyager polyphony
http://www.youtube.com/watch?v=QJsTbsth ... re=related
http://www.youtube.com/watch?v=DqEWGL3vh1A
Voyager polyphony
Re: Voyager Duophonics!
Where can I get one of those Voyagers with the case that changes colors?!?
No tht's not actually the case changing colors, its some kind of video magic.
This topic is in the Voyager section, but it isn't bad for a shameless post pad.. He's asking on the Youtube, "how do I do it?" I hear a delay unit, and in some places I'm only hearing one note when the upper notes are played, although the same envelope of the lower tone is still heard.
Minimoog Model D, Roland SH-1, Simmons SDS-8, Rhodes 73 suitcase, Ludwig/Gretsch Drums, Zildjian/Paiste/UFIP cymbals, Various acoustic percussive effects
Thanks Eric!!EricK wrote:THe best Moog Polyphony Ive seen yet...
Voyager polyphony
I'm a Japanese Prog Rock keyboardist.
I love Balkan music such as Bulgaria & Romania.
Greetings!
Greetings!
Electrong wrote:This topic is in the Voyager section, but it isn't bad for a shameless post pad.. He's asking on the Youtube, "how do I do it?" I hear a delay unit, and in some places I'm only hearing one note when the upper notes are played, although the same envelope of the lower tone is still heard.
You are hearing both “tones” on one note because he has it set up so that one Voyager is low note priority and the other high note. When you press on key or the controlling Voyager only that note will sound on both instruments, if you hold down a key, then play keys above that, only the sound on the Voyager set for low note will sound, while you can play something else on the “sound” on the high note assigned Voyager.
OK thanks.. makes total sense. I thought I was hearing high note priority and low note priority.. So you know he's got a module or another voyager hooked to this via Midi? I'm also hearing a delay effect in there.Brian G wrote:Electrong wrote:This topic is in the Voyager section, but it isn't bad for a shameless post pad.. He's asking on the Youtube, "how do I do it?" I hear a delay unit, and in some places I'm only hearing one note when the upper notes are played, although the same envelope of the lower tone is still heard.
- latigid on
Can't you see another KB Voyager in the background??
