Mod wheel control
Everything Phatty.
mab
Mod wheel control
Post by mab » Mon Mar 29, 2010 9:23 am
Hi All,
Here's my first question (a newbie one actually) to this forum. I have an expression pedal that I want to use to control the mod wheel. How can I do that ?
Thanks for your help!
-mab
Sir Nose
Post by Sir Nose » Mon Mar 29, 2010 10:07 am
The LP does not have a voltage control input to the mod amount just filter, pitch, and volume (gate trigger too). A midi CC pedal will work. For a 7-bit pedal CC#1. I don't know if any stepping will be present with the low res, but it might be on some patches. If you are running OS 2.0 or higher you can use a high res 14-bit midi CC with the MSB=1 and LSB=33. Pedals that send 14-bit midi CCs are expensive though. There's probably other solutions using the expression pedal with some sort of hardware/software to create the midi message.
_DemonDan_
Post by _DemonDan_ » Mon Mar 29, 2010 12:21 pm
Sir Nose wrote:If you are running OS 2.0 or higher you can use a high res 14-bit MIDI CC with the
MSB=1 and LSB=33. Pedals that send 14-bit MIDI CCs are expensive though.
This one's not too expensive and has lots of uses:
http://www.behringer.com/EN/Products/BCF2000.aspx
It has nice, long-throw faders and can send 14-bit CC messages.
If you look at section "5. Appendix" in the manual you can see all the available message types:
http://www.behringer.com/EN/downloads/p ... 7_M_EN.pdf
