I posted my set up on the Elektron-users forum where I got an answer to my problem.
Someone else had the same set up and found that Midi only works after you unplug the midi In on the LP and plug it back in,
And commonly midi only works if you power down the LP, turn it back on then replug in the midi.
A friend on the Machine drum site recommended posting the news here.
A suggestion that maybe the LP needs a firmware update? (I don't know)
I hope Amos spots this one
