updating (os 3.5) with sysex librarian
barrie
Post by barrie » Thu Mar 18, 2010 5:52 pm
After a great deal of help I've managed to save my presets using SysEx Librarian and I'm now ready to update from 3.3 to 3.5. Would anyone be able to provide step by step instructions for a rather nervous newbie?
Thanks Barrie
till
Post by till » Thu Mar 18, 2010 6:04 pm
I recommend strongly to do a back up before the updates. You did this now.
And it is better to do one step a time when upgrading, because this is the way it was tested.
So first from 3.3 to 3.4
And then to 3.5
Will take you 5 mins more. But better then having a problem.
Please read the instructions of Moog on how to do the update. And follow it step by step!
And what computer do you use? What computer software? Without this there is no step by step instruction possible.
barrie
updating via SysEx
Post by barrie » Sat Mar 20, 2010 3:02 am
Hi Till, thank for taking the time to help. Do you know where I get version 3.4?
BW
Barrie
barrie
updating via SysEx
Post by barrie » Sat Mar 20, 2010 3:04 am
sorry, forgot to mention that I'm using a Mac running OS 10.6
B
RL
Re: updating via SysEx
Post by RL » Sat Mar 20, 2010 5:53 am
barrie wrote:Hi Till, thank for taking the time to help. Do you know where I get version 3.4?
BW
Barrie
You don't need version 3.4 when you want to update from 3.3 to 3.5.
Have fun,
Rudi
ghostrider45
Update 3.3 to 3.5
Post by ghostrider45 » Sat Mar 20, 2010 7:05 am
I just updated my Electric Blue from 3.3 to 3.5. The load sequence described in the 3.5 Release Notes did not work. The sequence described in the 3.4 Release Notes (B,A, C,D) did the trick.
BTW, the update reset the LCD contrast on my machine. Also be sure to back up your presets before you start. You'll have to reload them after the upgrade.
till
Re: Update 3.3 to 3.5
Post by till » Sat Mar 20, 2010 1:03 pm
ghostrider45 wrote:...
BTW, the update reset the LCD contrast on my machine. ...
This is normal.
Also the chosen start-up screen is set back to the default value (the new logo, not the Bob Moog picture).
barrie
Rudi
Post by barrie » Sun Mar 21, 2010 6:27 pm
Thanks for your reply.
I wonder if you can advise on the step by step process of uodating using SysEx (I've saved my presets, although it seems to be one file rather than the separate banks that are often mentioned). I also wonder about this when uploading the new OS. B
Prime NL
Post by Prime NL » Mon Mar 22, 2010 5:12 am
You can read a step-by-step process in the Voyager OS 3.5 Release Notes : http://www.moogmusic.com/manuals/voyage ... _notes.pdf
RL
Post by RL » Mon Mar 22, 2010 12:43 pm
Prime NL wrote:You can read a step-by-step process in the Voyager OS 3.5 Release Notes : http://www.moogmusic.com/manuals/voyage ... _notes.pdf:
Better:
Prime NL
Post by Prime NL » Mon Mar 22, 2010 1:20 pm
Tx Rudi...edited my post... :wink:
barrie
Post by barrie » Mon Mar 22, 2010 1:21 pm
Thanks guys
RL
Post by RL » Mon Mar 22, 2010 1:44 pm
Prime NL wrote:Tx Rudi...edited my post... :wink:
No problem... will you be on the Musikmesse?
I'll be there on Friday and Saturday.
Have fun,
Rudi
till
Post by till » Mon Mar 22, 2010 2:18 pm
Hi Rudi, see you friday.
RL
Post by RL » Mon Mar 22, 2010 2:18 pm
till wrote:Hi Rudi, see you friday.
Great!!!!!!!!!!!!
:D :D :D
