cubase(?) is killing my moog
I don't know if it's cubase or the voyager, but it seems now almost every time I try and edit a patch while cubase is running, It will shut off all sound, and I have to either turn the voyager on and off or reload the patch. the problem starts when I'm turning a knob, any knob, and the sound will just die.
it will only happen while cubase is on, stand alone I cannot recreate this problem.
This used to only happen once and a while, but this last week it's been happening constantly.
It also used to only happen with certain cubase files, now it happens with all of them.
This is such a random problem I don't even know how to trouble shoot it.
Has anyone else had problems like this?
it's a midi interface issue
I just realized it's my sound card, tascam us-122... When the port is on emulated, the only way it will record midi, it screws it up... I have to switch back and forth from emulated to regular depending on if I want to record or turn knobs.
At least I got it working.
Ah, cubase and the emulated ports story. If you don't already have it, you should get this document
